Last Post: ronccc
0 points/condenser
0 2004 ICM
Last Post: LLOYD883
0 A couple more noob questions
Last Post: Bikeaholic
0 Lifter / Tappet Please Gimme a Hand
0 Michigan Thumb Run:
0 Craigslist
0 How to long term storage?
0 Rear Crash Guard/Bag Guard Needed
Last Post: Turbo Sporty 48
0 Wanted: Mid Controls for Frame Mount Evo
Last Post: 5mel42
0 A Day in the Life...
0 Laughing shotgun pipes...Kickstarter hits pipe
Last Post: Oldmxdog61u
0 Proper XLCH
0 Momentary starter switch installation question
3 Start System Testing
Last Post: LetsDoIt
0 Short Shots w/mid controls
0 Ok 1200 to 1275 for street performance
0 Power cones
Last Post: Serious Blac
0 2006 Sporty Charging System Upgrade
0 Un-Modded 2013 Forty-Eight Wobble
0 Need help with ideas..
Last Post: robbie202
jlede (70), hissatsu (65), Mickey Shane (65), jiffylube (54), TEAMGREEN (49), pirogue1 (45), soupman77 (44), kromroykw (43), O48 (43), dracolich, STEVOMERCKX (35)
1200, 1972, 2006, fluid, tranny, transmission
Old 6th July 2008
jonathanrichardporter@hot jonathanrichardporter@hot is offline
Sportster/Buell Year: 1973
jonathanrichardporter@hot is an unknown quantity at this point
Default tranny fluid
hey i just bought my first bike a 1973 xlch and i want to change all the fluids. ive searched every were but i never can seem to get a straight answer. it just seems to turn into a pissing match about who uses the best fluid, wether it be sport trans of fourmula + or just plaint 75w 90. i dont mean to be short with anyone but i would just like to know the absoulute definitive answer on this. thank you.
Old 6th July 2008
gusotto's Avatar
gusotto gusotto is offline
Sportster/Buell Model: XL1200
Other Motorcycle Model: Harley Ultra Classic
Other Motorcycle Year: 2007
gusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant future
Sport-Trans is listed for '71 bikes and newer in the P&A book.
Probably hard to find now as a lot of dealers only carry Formula+, the replacement fluid for Sport-Trans.
Either would be fine to use.
Other manufacturers make primary/transmission fluids for a Sportster.
Bel-Ray, RevTec, Spectro are some that come to mind.
I've used Harley Sport-Trans, RevTec and Bel-Ray and they all have worked fine.
I use Spectro semi-synthetic 20W50 engine oil so I wouldn't mind trying their primary/trans fluid but it's just harder to find.
All will work fine.
Change oil (no matter what brand you chose) when needed and you'll do fine.
"Beer has food value but food has no beer value."
2002 XL 1200 SE A/C & SE mufflers Mustang seat, Harley Hard Bags, Detachable Backrest w/Luggage Rack Kuryakyn Stop/Turn Signal Controller w/pulse brake, Pegs and Stirrups, Forward Controls, Memphis Fats Windshield
Old 6th July 2008
misterT's Avatar
misterT misterT is offline
Sportster/Buell Model: 1200R 90+HP
Sportster/Buell Model #2: 2276cc VW sandrail
Sportster/Buell Year #2: 1976
misterT is a glorious beacon of lightmisterT is a glorious beacon of lightmisterT is a glorious beacon of lightmisterT is a glorious beacon of lightmisterT is a glorious beacon of lightmisterT is a glorious beacon of lightmisterT is a glorious beacon of lightmisterT is a glorious beacon of lightmisterT is a glorious beacon of lightmisterT is a glorious beacon of lightmisterT is a glorious beacon of light
I use the formula+ in the tranny, like gusotto said I think any motorcycle tranny fluid would be fine. The 75w90 would probably work fine too the only difference is the tranny fluid has addatives for the wet clutch. I have read a few threads on here about problems using synthetic motor oil in the primary though the MOCO says it's O.K.
04 1200R 90+HP/10.5-1 SE pistons/.536 cams/Heads by MR T/mikuni HSR 42 w/25 pilot, 96 needle, 170 main/TC88A ignition w turbotas mod 33 map pos.4/ Supertrapp 2-1 w 23 disks/ 28T FRONT PULLEY /NRHS Hurricane A/C & adj. pushrods /progressive 440 shocks & fork springs w/10 OZ SE fork oil
Old 13th March 2009
83XLXCT's Avatar
83XLXCT 83XLXCT is offline
Sportster/Buell Model: XLX 61"
Sportster/Buell Year: 1983
83XLXCT is an unknown quantity at this point
used the Harley trani+ fluid and now the clutch is slipping a bit around 3 grand? any ideas?
Old 14th May 2009
FastHoss FastHoss is offline
Sportster/Buell Model: 1200n
Sportster/Buell Year: 07
FastHoss is on a distinguished roadFastHoss is on a distinguished roadFastHoss is on a distinguished road
60 wt motor oil same as the engine
