Last Post: ronccc
0 points/condenser
0 2004 ICM
Last Post: LLOYD883
0 A couple more noob questions
Last Post: Bikeaholic
0 Lifter / Tappet Please Gimme a Hand
0 Michigan Thumb Run:
0 Craigslist
0 How to long term storage?
Last Post: Turbo Sporty 48
0 Wanted: Mid Controls for Frame Mount Evo
Last Post: 5mel42
0 A Day in the Life...
0 Laughing shotgun pipes...Kickstarter hits pipe
Last Post: Oldmxdog61u
0 Proper XLCH
0 Momentary starter switch installation question
3 Start System Testing
Last Post: LetsDoIt
0 Short Shots w/mid controls
0 Ok 1200 to 1275 for street performance
0 Power cones
Last Post: Serious Blac
0 Un-Modded 2013 Forty-Eight Wobble
0 Need help with ideas..
Last Post: robbie202
jlede (70), hissatsu (65), Mickey Shane (65), jiffylube (54), TEAMGREEN (49), pirogue1 (45), soupman77 (44), kromroykw (43), O48 (43), dracolich, STEVOMERCKX (35)
1972, basket case, build, ironhead
Old 3rd July 2011
Originally Posted by dbaker88 View Post
He has a clear title registered to the motor not the frame and i've ridden rigids quite a bit i've got an 88 sporty bobber on a rigid with a slight rake and love it. I haven't seen the bike yet so i'm not sure how the quality is on the welding and such.
A 72 is not registered by the motor number.
The number on the frame is what DMV uses.
A LEO will look at the motor numbers last.
There could be another bike out there registered under that frame (motor) #, that bike will hold the legally registered status over yours.
You will need paper on the frame to transfer ownership.
Without paper on the frame you will likely be given a "Special Construction" title not a "HD".
Check this out with DMV before purchasing.
Old 3rd July 2011
I would not purchase anything without a perfect title situation. You may get it legal in your justidiction and run into trouble elsewhere where the rules are different or more rigidly enforced.
Check it out carefully. If you buy you will be putting in a lot of time, money and love into ...
Old 3rd July 2011
dbaker88's Avatar
dbaker88 dbaker88 is offline
Sportster/Buell Model: Sportster bobber 883/1200
Sportster/Buell Year: 1988
Other Motorcycle Model: too many
Other Motorcycle Year: many
dbaker88 has a spectacular aura aboutdbaker88 has a spectacular aura aboutdbaker88 has a spectacular aura aboutdbaker88 has a spectacular aura aboutdbaker88 has a spectacular aura aboutdbaker88 has a spectacular aura aboutdbaker88 has a spectacular aura aboutdbaker88 has a spectacular aura aboutdbaker88 has a spectacular aura about
Ya i definetely want to get the title situation figured out first before i buy it.
Has anyone built the motor from ground up total rebuild.
Lets say the cases are good but i do all internal, what do you think parts would cost to build the motor up right. I know that's an impossible question but i'm just lookin for a rough ball park or worst case situation. what you guys started from and spent to do it.
Old 3rd July 2011
flathead45's Avatar
Sportster/Buell Year: 86
Other Motorcycle Year: 1945
my cases were busted when i bought mine. i tore it down to the point of pressing the crank out. then had an indy shop weld it, machine it, and reassemble it. cost me 900 bucks ten years ago.
my bottomend is oil tight and don't drip a bit. well worth having the indy do the work in my book. plus i can't machine stuff.
"lord of the Night Lite"
thank god for darwin ;)
Old 3rd July 2011
dbaker88's Avatar
That's what i'm considering flathead. I don't have the machine tools or really that much experience to do it. I'm thinking have the motor built by professionals and i'll do the rest.
Anybody else had this done?
Old 3rd July 2011
the cowboy way's Avatar
the cowboy way the cowboy way is offline
Sportster/Buell Model: hand built M/XL ironhead
Sportster/Buell Year: 9293
Sportster/Buell Model #2: 1976 motor in a 1987 fram
Sportster/Buell Year #2: ????
Other Motorcycle Model: 1974 XL & 2003 FXD
Other Motorcycle Year: 7403
the cowboy way has disabled reputation
I have rebuilt a motor using used parts
rods , pistons , valves & springs , ect
trannys also , espeically trannys
allways use new bearings & seals
I dont see a need on buying new when a good used part will work
Forever Two Wheels
1997 AMRA National E-class Champion
Ironhead parts I have tons of em
machine shop @ home
Old 4th July 2011
hogmania hogmania is offline
Sportster/Buell Model #2: xlh
Sportster/Buell Year #2: 1977
hogmania has a spectacular aura abouthogmania has a spectacular aura abouthogmania has a spectacular aura abouthogmania has a spectacular aura abouthogmania has a spectacular aura abouthogmania has a spectacular aura abouthogmania has a spectacular aura abouthogmania has a spectacular aura abouthogmania has a spectacular aura abouthogmania has a spectacular aura abouthogmania has a spectacular aura about
I'm with cowboy, a good used part it alot of the time much better than a cheap new part. and you can repair your part so much the better.
Old 4th July 2011
dbaker88's Avatar
I totally agree i'd like to use as much original parts i can. But with what i know about the old iron head motors i'd be more comfortable having a professional build the motor right. Has anyone else had their motor built i'd like to get a ball park on what it would cost.
