0 The Revolution's Rowdy Ancestor?
Last Post: RDHenley
0 How packed is your garage?
Last Post: RDHenley
0 Generator removal
0 '81 Gasket/Rebuild Questions
0 Struggling with year??
Last Post: Calcustom
0 oil line routing 79 ironhead
Last Post: bobandy
0 Forum member mug shots
0 THE Hockey Thread
0 4 Speed Stator Replace
Last Post: connorneil13
0 Polished rotor/brake pad compatability
Last Post: Firehawk
Last Post: Firehawk
0 Dynatek Ignition questions
0 compression low?
Last Post: 93trident
0 Hello from the uk I just got my first Harley!
Last Post: Sugarsinner
5 1969 XLCH exhaust question
Last Post: Coz
0 I'm back...
Last Post: screndname
0 Random video thread.
5 RSD LED Indicator
Last Post: mk87ita
Last Post: RDHenley
Last Post: RDHenley
DAKSY (68), dwagar (68), DaveDuff (59), chaserband (57), bigcraig74 (46)
bearing, cam, spun
Old 10th November 2014
04xl1200c's Avatar
04xl1200c 04xl1200c is offline
Bike Builder
Other Motorcycle Model: CB750k SOHC
Other Motorcycle Year: 1977
04xl1200c has a brilliant future04xl1200c has a brilliant future04xl1200c has a brilliant future04xl1200c has a brilliant future04xl1200c has a brilliant future04xl1200c has a brilliant future04xl1200c has a brilliant future04xl1200c has a brilliant future04xl1200c has a brilliant future04xl1200c has a brilliant future04xl1200c has a brilliant future
Thumbs down 04 1200C 40k mi engine failure :(
Well I've been chasing what seemed like a lifter noise... last week it got really loud (I fixed my noise from my clutch basket and primary chain) then the engine lost power and died
I tore down the motor and found 2 bent push rods, front cyl intake cam seized in the engine. exhaust cam's bushing in the block spun, exhaust valve hit the piston and bent it. back cyl exhaust valve hit the piston. the piston skirts are badly scored and there is scorring on the cyl walls.
rocketmangb's Avatar
Check that pinion gear and oil pump gears
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
David
Did that motor come in the bike ?
I question the oil pump plumbing !
oregonboomer oregonboomer is offline
Sportster/Buell Model: xl1200 c
Other Motorcycle Model: FLHRC-I
oregonboomer will become famous soon enoughoregonboomer will become famous soon enoughoregonboomer will become famous soon enoughoregonboomer will become famous soon enoughoregonboomer will become famous soon enoughoregonboomer will become famous soon enoughoregonboomer will become famous soon enoughoregonboomer will become famous soon enough
Oh dude! Sorry man, that looks terrible...... right off the top, something I dealt with a while back, excess oil blow-by caused buildup in the combustion chamber, the valves got restricted, and started beating up the valve train.... just my best given what little I know, but your cyl rings look fried and busted. Lots of oil use prior to this?
04xl1200c's Avatar
Bike Builder
David
YES its the stock motor... that's the oil plumbing for the OEM oil cooler... its a PAIN to install..
and it was not using oil...
I love my Samson Powerflow III 2-1 Exhaust
DaytonaSportster's Avatar
DaytonaSportster DaytonaSportster is offline
DaytonaSportster has a reputation beyond reputeDaytonaSportster has a reputation beyond reputeDaytonaSportster has a reputation beyond reputeDaytonaSportster has a reputation beyond reputeDaytonaSportster has a reputation beyond reputeDaytonaSportster has a reputation beyond reputeDaytonaSportster has a reputation beyond reputeDaytonaSportster has a reputation beyond reputeDaytonaSportster has a reputation beyond reputeDaytonaSportster has a reputation beyond reputeDaytonaSportster has a reputation beyond repute
That piston top does look VERY wet and since it been a while IMHO that is oil and not gas.
Time for a 1250 kit and head work from your preferred XLForum vendor!
http://xlforum.net/forums/showthread.php?t=842245
The crank is probably hurt as well as the cases.
lugster's Avatar
lugster lugster is offline
Sportster/Buell Model: xl883r
lugster has a reputation beyond reputelugster has a reputation beyond reputelugster has a reputation beyond reputelugster has a reputation beyond reputelugster has a reputation beyond reputelugster has a reputation beyond reputelugster has a reputation beyond reputelugster has a reputation beyond reputelugster has a reputation beyond reputelugster has a reputation beyond reputelugster has a reputation beyond repute
How long have you had the oil cooler?
04xl1200c's Avatar
Bike Builder
for a long time... when the bike had about 12k miles. ya I think the crank may have some damage... ya I'm trying to get an idea on what would be a good yr motor for replacement?
fusion213's Avatar
fusion213 fusion213 is offline
Sportster/Buell Model: 883
fusion213 has a spectacular aura aboutfusion213 has a spectacular aura aboutfusion213 has a spectacular aura aboutfusion213 has a spectacular aura aboutfusion213 has a spectacular aura aboutfusion213 has a spectacular aura aboutfusion213 has a spectacular aura aboutfusion213 has a spectacular aura aboutfusion213 has a spectacular aura aboutfusion213 has a spectacular aura aboutfusion213 has a spectacular aura about
Some of that damage looks very similar to what happened to OCGreen's bike.
