0 Proper XLCH
Last Post: Bigshankhank
Last Post: spoon
0 V&H Short Shots Pipe Test - Mild 1250
Last Post: SLW210
0 Stock (?) 1974 cobra style seat won't fit.
Last Post: 1Scooter
0 Top End Whirring Sound
Last Post: 201648Rider
0 It's me - Kokopeli.
0 Crank Seal Missing; Is My Engine Damaged?
0 Show us a picture of your truck
0 2004 ICM
0 Getting Hammered
Last Post: carbonizedeyesockets
Last Post: geekonabike
0 Do people notice your bike?
0 Black Bike Bible
Last Post: Kokopeli
0 Possible air leak?
Last Post: noprobrobb
0 01 sport 883 (Shortest Shocks)
Last Post: RDHenley
Loneduck1, Doug (71), PAS858 (46), Clanure (42), FF95EMT (38)
cam, harley, ironhead, sporty, stroker
Old 14th October 2016
nakina's Avatar
nakina nakina is offline
Sportster/Buell Year: 1968
Other Motorcycle Model: T100R
Other Motorcycle Year: 1973
nakina is a jewel in the roughnakina is a jewel in the roughnakina is a jewel in the roughnakina is a jewel in the roughnakina is a jewel in the roughnakina is a jewel in the roughnakina is a jewel in the roughnakina is a jewel in the roughnakina is a jewel in the roughnakina is a jewel in the roughnakina is a jewel in the rough
The hustler exhaust cams are the -- exhaust cams. So, with -- intakes, you would have a full set of -- (or -/-, minus/minus, 207, Titan, etc... - however you want to name it).
The Sifton nomenclature can be a little confusing:
http://xlforum.net/dl/1981SiftonBookXLCams.pdf
OregonIronhead's Avatar
OregonIronhead OregonIronhead is offline
Sportster/Buell Model: Sportster Stroker
Sportster/Buell Year: 1976
OregonIronhead is an unknown quantity at this point
Ok I read somewhere that -- refers to matching lift across all 4 cams. Any truth to that
cazz1000 cazz1000 is offline
Sportster/Buell Model: xlx
I just went a hundred miles today with 202 hustlers. listen too chevelle lashed .08 super b 68 main 28 ind ive owned my xlx for 33 yrs go with -- exhaust p 2 3 intake everyone is telling u the right way too go god bless bye
run small valves -- exhaust 1 4 ps 2 3 ngk plugs bp5 hs no points electronic ing no drag pipes one piece pipe with baffles I respect chevelle listen too the old dudes I'm still riding
The reason is that my bike has high compression, and Chevelle is willing to sell me a 2&3 NOS cam that are -- .436 like the one that's munched. He said it would swap out direct.
Old 26th December 2016
I decided to go with Chevelle's advice and bought the -- intake cams off him. Mainly cuz my bike has very hi compression and the minus minus have same lift but longer duration plus the price was in my budget and he offered just the 2 I needed.
Installed them and it sounded great. But then oil came squirting out the oil pump. Found three stress cracks from overtightening. Now I will have to pull the motor so I can put a new oil pump on there. So I fixed the starter pinion and the cams, happy Christmas but broken oil pump grumbling grrr
if it broke where mine did,you can buy a,new housing and re-use your old gears,timed breather etc.
Old 28th January 2017
Installed and done
nakina's Avatar
Good to hear it! How does it run?
It runs freaking great, sounds super loud, pops wheelies!
