Last Post: Bikeaholic
0 A couple more noob questions
0 Lifter / Tappet Please Gimme a Hand
0 points/condenser
0 Michigan Thumb Run:
0 Craigslist
0 How to long term storage?
Last Post: Turbo Sporty 48
0 Wanted: Mid Controls for Frame Mount Evo
Last Post: 5mel42
0 A Day in the Life...
0 Laughing shotgun pipes...Kickstarter hits pipe
Last Post: Oldmxdog61u
0 Proper XLCH
0 Momentary starter switch installation question
3 Start System Testing
Last Post: LetsDoIt
0 Short Shots w/mid controls
0 Ok 1200 to 1275 for street performance
0 Power cones
Last Post: Serious Blac
0 Un-Modded 2013 Forty-Eight Wobble
0 Need help with ideas..
Last Post: robbie202
0 Problem on a trip
jlede (70), hissatsu (65), Mickey Shane (65), jiffylube (54), TEAMGREEN (49), pirogue1 (45), soupman77 (44), kromroykw (43), O48 (43), dracolich, STEVOMERCKX (35)
1972, iron head, sportster
Old 24th June 2019
xlhshawn xlhshawn is offline
Sportster/Buell Year: 1972
xlhshawn is an unknown quantity at this point
i had got a new 1972, that had black, I worked on assembly line at the york,ap plant went they built 1st one there, which was 1973, they were black also, thanks for the clarification " brucstoudt " maybe you can help with other questions i have on this site....thanks to everyone
Old 25th June 2019
owlsplace owlsplace is offline
Sportster/Buell Model: XLH 1000cc
Sportster/Buell Year: 1981
owlsplace has much to be proud ofowlsplace has much to be proud ofowlsplace has much to be proud ofowlsplace has much to be proud ofowlsplace has much to be proud ofowlsplace has much to be proud ofowlsplace has much to be proud ofowlsplace has much to be proud ofowlsplace has much to be proud ofowlsplace has much to be proud ofowlsplace has much to be proud of
Rustoleum hi-temp brush painted from the box store straight over chrome, rust, etc with little to no prep.
Sent from my SM-S767VL using Tapatalk
Old 25th June 2019
Whitewalls's Avatar
Sportster/Buell Year: 1971
Whitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant future
I never pay attention to what they looked like when new. I paint it to look like what I want.
As far as painting the heads and jugs. I have painted many and tried different methods and brands. The best results I have obtained are from using Duplicolor engine enamel. It is available in many colors at most auto parts stores.
Prepping the pieces is critical to getting good results. Remove all rust, corrosion and oxidation down to clean metal.
To get good long term quality results you need to use the Duplicolor engine enamel in 3 parts and follow the instructions on the can pertaining to time between coats. They have primer, paint and clear coat. Not using all 3 will give you short term results. Ask me how I know.
Using the 3 part method, I have several projects that still look fresh after several years and many miles.
Good luck.
Old 25th June 2019
thank yo, does the clear give a glossy look ? thanks
Old 25th June 2019
Whitewalls's Avatar
It's just a clear coat that seals and protects the paint. If you spray it on gloss paint it looks gloss. If you spray it on flat it looks flat.
Old 25th June 2019
ok thanks, i will check into that, i have had very good result with hd wrinkle paint, just not the finish i'm after, thanks again
Old 25th June 2019
Whitewalls during your knucklehead build you may experience an epiphany,or not?
Old 26th June 2019
Whitewalls's Avatar
Epiphany? If I ever get to build a knucklehead with my budget it will surely be a basket case project of many acquired parts. I just cant see going through all of the time and work to build a bike that will look bone stock. When its all said and done its still not an original bike as its been restored.
I like to build a bike from many parts and pieces that is safe, reliable and with a mild custom look.
Old 26th June 2019
Whitewalls's Avatar
Here are a couple examples of my work. I don't believe either of these bikes looked better when they were brand new.
IMG]://2ldfu6g.pngi64.tinypic.com/[/IMG]
Old 26th June 2019
Whitewalls's Avatar
