0 Valve Lengths?
0 73 XLH Total Power Loss
Last Post: Erikdowney18
0 Cleaning carbon build-up
Last Post: vt883
Last Post: commando57
0 Gasket placement
Last Post: Billy1200
0 XR mutt race bike progress
0 Info needed on mini sumps.
0 What oils do you run in your ironhead
0 Lifters+w cams
Last Post: supermotolew
0 HF bike lift
Last Post: salmanmr
Last Post: jharback
0 Chasing Down Leaks
Last Post: ericfreeman
0 Main shaft bearing preferences
Last Post: Heff
0 Chinese S&S carbs
0 Tire pressure
0 K/n air filter,, and s/s super b long thumb screw bolts
vt883, Danno, Otis_hd (70), Fisherman (69), New Girl (63), soup (58), motormyk (51), leo, UncleSmitty (43), bryguy1977
Old 9th April 2020
SonWon SonWon is offline
Sportster/Buell Model: Superlow 1200T
Sportster/Buell Year: 2016
SonWon has a reputation beyond reputeSonWon has a reputation beyond reputeSonWon has a reputation beyond reputeSonWon has a reputation beyond reputeSonWon has a reputation beyond reputeSonWon has a reputation beyond reputeSonWon has a reputation beyond reputeSonWon has a reputation beyond reputeSonWon has a reputation beyond reputeSonWon has a reputation beyond reputeSonWon has a reputation beyond repute
Default 2016 Oil Drain Hose Has Cracks
Yesterday, I was going to change the oil on my 2016 Sportster. When I went to pull the plug in the oil drain hose I discovered the line had several cracks. Oddly I can only see the cracks on the plug side of the oil line. I will know more after I replace the line. Also I examined the other oil lines and they look okay. I am wondering if I should replace all of the hoses? Is there any history of trouble with the oil lines cracking or bursting?
The bottom two oil lines on the oil tank are damp with oil. I believe this is from the clamps and plan to replace them both with proper ones in place of those crimp clamps. The top two lines are dry so I'll leave those alone. Or maybe the oil drain line is cracked around the crimp clamp where I can not see?
Old 9th April 2020
rokytnji's Avatar
rokytnji rokytnji is offline
Sportster/Buell Year #2: 1983
Other Motorcycle Year: 1990
Dry rot is usually exhibited when the hoses get hard .
Any iffy stiff hoses I find., I replace.
Stock sucks.
Traveled to
Old 9th April 2020
NGOT8R NGOT8R is offline
Sportster/Buell Year: 2019
NGOT8R has much to be proud ofNGOT8R has much to be proud ofNGOT8R has much to be proud ofNGOT8R has much to be proud ofNGOT8R has much to be proud ofNGOT8R has much to be proud ofNGOT8R has much to be proud ofNGOT8R has much to be proud ofNGOT8R has much to be proud ofNGOT8R has much to be proud ofNGOT8R has much to be proud of
That is rather soon for a 2016 to have the oil lines from the tank dry-rotting. Has the bike been kept outside? Just wondering, but then again, maybe they could be cheap quality rubber hoses that the MoCo used. IMO, it appears that they like to use substandard parts at times, but want to charge premium prices for their product. Having said all of that, if I were you, I would look for better quality hoses and change all of them at the same time, so that they are on the same maintenance schedule. Hopefully you will get much a better lifespan out of an improved product.
Old 9th April 2020
I have the new hose now and it is softer than the old one however I would expect that. It appears to me that the oil drain hose is a different type of hose than the other three. I suspect this is true since there is no pressure on the hose other than the weight of the oil in the tank. I can detect no reinforcement metal or cord inside the hose. I would expect the other hoses are reinforced since they carry pressure, not cutting them open to find out.
It does appear the old hose could have dry rotted. I guess the hose dried out shrunk and therefore cracked. When you look into the crack areas it almost appears there is another hose under the crack. The new one is solid hose so I don't know. I too was surprised that it had cracks. If it had let go it could have made for an exciting time on the Autobahn at 90 mph. I am glad I will not get a chance to experience that.
I will examine the remaining hoses carefully when it is on the lift for the oil change.
Old 9th April 2020
Oh, the bike is stored outside under a carport with a cover over the bike. The cover keeps the sun off everything below axles and foot pegs. I have cardboard protecting the front tire from direct sunlight. So the sun never reaches any of the rubber stuff accept when riding.
Old 9th April 2020
Oh ok, well I’m glad you noticed it when you did and are taking corrective action. It could have been disastrous from both safety and mechanical standpoints.
Old 10th April 2020
I've been thinking this through and it is possible last year or before I could have sprayed that hose with a cleaner that degraded the hose which would explain why it is only degraded on one end. Once I get the hose out I will know for sure how far the cracks go.
Old 10th April 2020
Highly-Dangerous's Avatar
SPANIARD
Weird/Interesting... keep us posted on your findings.
Pics?
CLICK->>"Maintenance is as much art as it is science"<<-CLICK
Old 11th May 2020
Sorry for not getting back sooner. I've um been test riding.
The oil is changed and the line is replaced. There were only cracks on the plug side of the hose. So I must have sprayed that hose at least once with brake cleaner. Apparently the hose material is not compatible with brake cleaner which I find odd since there are rubber pieces in the braking system. Anyway if you have sprayed brake cleaner on the hose you best check it for cracks and if you have not then don't!
The hose is easy to replace. I suggest removing the belt guard first, only two bolts. Tape the end of the new hose before pushing it through to keep slime out. Oh, drain all the oil first too or you will get an unpleasant surprise.
Removing the old clamps was the worst part since I was a little concerned for the oil tank. I used heavy duty wire cutters and had to twist a little too. I used regular screw clamps to put it back together. I did something right since there are no oil leaks.
Old 11th May 2020
SPANIARD
Good to know. Thank you.
