0 Valve Lengths?
Last Post: motorhedmike
0 73 XLH Total Power Loss
Last Post: Erikdowney18
Last Post: Mike1nw
0 Cleaning carbon build-up
Last Post: vt883
Last Post: commando57
0 Gasket placement
Last Post: Billy1200
0 XR mutt race bike progress
0 Info needed on mini sumps.
0 What oils do you run in your ironhead
0 Lifters+w cams
Last Post: supermotolew
0 HF bike lift
Last Post: salmanmr
Last Post: jharback
0 Chasing Down Leaks
Last Post: ericfreeman
0 Main shaft bearing preferences
Last Post: Heff
0 Chinese S&S carbs
0 Tire pressure
0 K/n air filter,, and s/s super b long thumb screw bolts
vt883, Danno, Otis_hd (70), Fisherman (69), New Girl (63), soup (58), motormyk (51), leo, UncleSmitty (43), bryguy1977
evo sportster, forty eight, front end, front end mod, front wheel
Old 19th May 2017
irontoph irontoph is offline
Sportster/Buell Model #2: XL1200X Forty-Eight
Sportster/Buell Year #2: 2016
irontoph is an unknown quantity at this point
Default Front Wheel Swap on a 2016 SPortster Forty Eight
I just picked up a 2016 Sportster 48 and want to swap the front mag wheel out for either a 19 or 21 inch spoke wheel. Does anyone know if I can swap the front wheel over from another model without having to swap out the whole front end or brake set up? I know my 48 has 49mm forks with a 1 inch diameter axle and single disc brake. Looking for a solution that will allow me to just swap a wheel over and retain the rest of my stock set up. Any help would be appreciated. Thanks!
Old 21st May 2017
nativebroncofan's Avatar
nativebroncofan nativebroncofan is offline
Sportster/Buell Model: XL 1000
Sportster/Buell Year: 1979
Sportster/Buell Model #2: xl1200x
Sportster/Buell Year #2: 2019
nativebroncofan is a name known to allnativebroncofan is a name known to allnativebroncofan is a name known to allnativebroncofan is a name known to allnativebroncofan is a name known to allnativebroncofan is a name known to allnativebroncofan is a name known to allnativebroncofan is a name known to allnativebroncofan is a name known to allnativebroncofan is a name known to allnativebroncofan is a name known to all
Best advice I can offer is talk to stealeriship about it. Unless someone with more knowledge chimes in. I see that you are another Iron love'n 2016 48 owner just as I am.nativebroncofan
⛓ ALL CHAINED UP ⛓
Old 23rd May 2017
Billyj7175's Avatar
Billyj7175 Billyj7175 is offline
Sportster/Buell Model: Forty Eight
Sportster/Buell Year: 2012
Other Motorcycle Model: Street Bob
Other Motorcycle Year: 2009
Billyj7175 has a brilliant futureBillyj7175 has a brilliant futureBillyj7175 has a brilliant futureBillyj7175 has a brilliant futureBillyj7175 has a brilliant futureBillyj7175 has a brilliant futureBillyj7175 has a brilliant futureBillyj7175 has a brilliant futureBillyj7175 has a brilliant futureBillyj7175 has a brilliant futureBillyj7175 has a brilliant future
2006 and up Dyna's (not wide-glides or fatbob's) have a 19" spoke front wheel and midglide trees...
12' Forty-Eight (SOLD), 09' Streetbob, 17' BMW R1200GSA
