Last Post: Reverend G
0 clutch issue
0 Wont Fire up!
0 Warm/hot kickstart
Last Post: Mission1
0 "S" model specific Q&A
0 N65C or N65A
Last Post: lespaul6
Last Post: Hellbent_4
0 XR mutt race bike progress
0 Top end failure
Last Post: Mission1
0 Rubber mount gas tank part
0 Coil polarity
Last Post: davesz1r
0 '86 xl1100 help hooking up lights
0 Ebay ****evil knievel bike****
0 old style fender skirted
0 Difference in Clutch Levers 45356-07 vs kit 44992-07
0 Ground Up Beginner Build
0 Sportster Fork Upgrade
Last Post: PetesPonies
Last Post: smilinbrad
Gold951 (69), tujbob (65), tcspannerwrench (54), rondog (51), scootsgal (49), barney27 (46)
Old 21st December 2016
xl2000883/1200 xl2000883/1200 is offline
xl2000883/1200 is a splendid one to beholdxl2000883/1200 is a splendid one to beholdxl2000883/1200 is a splendid one to beholdxl2000883/1200 is a splendid one to beholdxl2000883/1200 is a splendid one to beholdxl2000883/1200 is a splendid one to beholdxl2000883/1200 is a splendid one to beholdxl2000883/1200 is a splendid one to beholdxl2000883/1200 is a splendid one to beholdxl2000883/1200 is a splendid one to beholdxl2000883/1200 is a splendid one to behold
Good luck. I like what a 2-1 exhaust does to low end and the plugs seemed to amplify it.
Green hornet's Avatar
Green hornet Green hornet is offline
Sportster/Buell Model: Sportster 72
Other Motorcycle Model: Honda CBR 1000RR DragBike
Green hornet has disabled reputation
That's a nice dyno sheet.
I have to ask, you said your rear cylinder is the hotter one. Did you get temp readings to confirm this? Just asking because the front is almost always the hotter one on sporties.
Default My 2000 883/1200 dyno run today
I took a guess at the rear being hotter since it's being blocked by the front cylinder and the front plug was darker by a few shades. It's mothballed for the winter. I'll have to take my temp gun on a ride next season.......
The plug has just normal part throttle and some spirited street riding. Nothing very aggressive and mostly riding on the needle not the main jet
Tom's Avatar
Tom Tom is offline
Sportster/Buell Model: 883R
Other Motorcycle Model: '84 FXE Super Glide
Tom has a reputation beyond reputeTom has a reputation beyond reputeTom has a reputation beyond reputeTom has a reputation beyond reputeTom has a reputation beyond reputeTom has a reputation beyond reputeTom has a reputation beyond reputeTom has a reputation beyond reputeTom has a reputation beyond reputeTom has a reputation beyond reputeTom has a reputation beyond repute
Nice dyno run! I was liking the results you got with the spark plug change and thought I'd look up some of those NGK's in the stock -7 heat range...no luck, they don't make them. Just a FYI to folks with stock type bikes.
*Edit, looks like they don't make a colder -9 also. Seems like the -8 is a specialty plug for oil head BMW twins.
Old 22nd December 2016
Originally Posted by Tom View Post
Nice dyno run! I was liking the results you got with the sprk plug change and thought I'd look up some of those NGK's in the stock -7 heat range...no luck, they don't make them. Just a FYI to folks with stock type bikes.
They (the EK plugs) were put in the week before. And yes that is I believe the only bike those plugs are specked for. Thankfully the local shop owner is a Beamer guy and had a box of them. He had the platinum version too. I tried crossing the 7 heat range to a Denso and no luck. My ninja (98 ZX9R) uses a CR9EK plug. But I think it's a different plug size.
I do not know if that flat torque curve is the plugs or the combination of cams, 2-1 LSR exhaust, 883 heads etc......I lost the dyno chart from the first run to see what it looked like with the S&S shorty E. Like I said that room was hot as hell. And my ZX9R was down 8hp from the previous time I had it there. (I talked my brother into riding it there so I could do both bikes that day)
To add to the above. The CR series plug is a 10mm plug. Our D series is a 12mm plug. So in theory if I could find a sleeve to adapt a 10mm plug into a 12mm hold I'd have a hotter plug option.
The DCPR8EKC plugs are on Amazon for 10.82 each. Much cheaper than a shop cost.
