0 73 XLH Total Power Loss
Last Post: Erikdowney18
0 Valve Lengths?
Last Post: motorhedmike
0 Cleaning carbon build-up
Last Post: vt883
Last Post: commando57
0 Gasket placement
Last Post: Billy1200
0 XR mutt race bike progress
0 Info needed on mini sumps.
0 What oils do you run in your ironhead
0 Lifters+w cams
Last Post: supermotolew
0 HF bike lift
Last Post: salmanmr
Last Post: jharback
0 Chasing Down Leaks
Last Post: ericfreeman
0 Main shaft bearing preferences
Last Post: Heff
0 Chinese S&S carbs
0 Tire pressure
0 K/n air filter,, and s/s super b long thumb screw bolts
0 Cutting Out Cracking Popping, Etc, After Fully Warmed Up
Last Post: Rgm883
vt883, Danno, Otis_hd (70), Fisherman (69), New Girl (63), soup (58), motormyk (51), leo, UncleSmitty (43), bryguy1977
evo sportster, fat bob tanks
Old 24th April 2019
Flame__'s Avatar
Flame__ Flame__ is offline
Artist, rider, wrencher
Sportster/Buell Year: 1989
Sportster/Buell Year #2: 1988
Other Motorcycle Year: 2000
Originally Posted by Dshank14 View Post
The kit I have looks like it's going to sit too low to just use clamps but I only had it in position for a minute so I'll have a better idea when I actually go to mount it.. it would be nice if I could get away with that though and thanks for letting me know it's an option
Like I said, it's meant to be temporary. Play around with it. Maybe you'll have to place something to shim it up between the bracket and the backbone to get it where you like it. Also, check your new tanks, if they're used. They had a tendency to develop leaks around where the brackets are welded to the tank. We need pics!
Knees in the breeze.
Gamertag, PS4: Bikerdude__
Old 24th April 2019
Dshank14 Dshank14 is offline
Sportster/Buell Model: 1200
Sportster/Buell Year: 93
Dshank14 is an unknown quantity at this point
They are used and there's some kind of sealer in the exact spot you're talking about.. I'll get some pictures for sure
Old 27th April 2019
I got it all mocked up and everything looks good.. I had to raise the back mount an inch, the front 3 inches or so, and cut the bottom tab off.. I have pictures but I didn't pay the 20 bucks so I'm assuming I can't post them..
Old 28th April 2019
farmall farmall is offline
Sportster/Buell Year: 73
farmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond repute
Shovel tanks should be mounted very carefully so there is no bending load on the tabs when the mount bolts are tightened. They crack and break easily hence the rubber washers on later Softail split tanks. On the good side you get more fuel and repop tanks (check fit before painting) are plentiful if needed in future.
It's easy to shim the mount tabs with washers.
Old 28th April 2019
Flame__'s Avatar
You can use a free web photo hosting website, like Flikr or something. There's a thread somewhere about how to post pics.
