Last Post: Nrg2brn
Last Post: longride
0 Big Bore '03 883R :)
Last Post: Dustpan63
5 Oil pump pressure
0 How many helmets?
Last Post: clif02
Last Post: vagrant318
0 1979 XLH restore or not?
Last Post: Bstrdbike
Last Post: cazz1000
Last Post: Jarlaxle
Last Post: 1977iron
0 Bushing alignment
0 What oil temp do you run
Last Post: JKKO
0 Who's still riding???
Last Post: 1977iron
0 In Tank Oil Filter?
Last Post: Coz
0 Rocker Box Bolts & Torque
Last Post: htown16
0 What's your helmet?
Last Post: Lone Rider
0 The O-FISH-ALL Red Sportster Thread
0 Curious question (Wheelies)
Last Post: spitfirechopper
0 Celebrating Sportsterpedia's Third Anniversary
Last Post: maverick31210
0 Clutch Spring plate poll
Last Post: bimbo
0 Black Bike Bible
Last Post: Beelzeboss
0 Stabliser Tie-link 16232-04
hillclimber (69), burtondl2 (51), Cet (49), hagar71 (48), ShaneWolfe (47), grizdiesel (42), Confused89 (34), RAIDER0372 (33), spamer80 (33), svwannabe
  #51
Old 13th November 2013
rocketmangb's Avatar
Well its a bitch to wait out the cycles but !
Helped Twilkie do his and followed the procedures
Extra assembly lube and all it never had even a puff of white smoke !
Checked the barrel temps with a raytech thermo so no guessing !
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Alto Carbonite Clutch
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Jordan5150's Avatar
Jordan5150 Jordan5150 is offline
Sportster/Buell Model: 883C
Jordan5150 is a splendid one to beholdJordan5150 is a splendid one to beholdJordan5150 is a splendid one to beholdJordan5150 is a splendid one to beholdJordan5150 is a splendid one to beholdJordan5150 is a splendid one to beholdJordan5150 is a splendid one to beholdJordan5150 is a splendid one to beholdJordan5150 is a splendid one to beholdJordan5150 is a splendid one to beholdJordan5150 is a splendid one to behold
All this "wisdom" from a guy who suggests putting jb weld in your head ports.....
http://www.mototuneusa.com/power_news_--_homework.htm
~Grind~ ~Grind~ is offline
Sportster/Buell Year: 04
~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute
Originally Posted by Bob s hog View Post
im sure they can tell they seen lots of damaged parts .
You're right, I imagine they have. My bad.
"Only Fools Celebrate A Fool"
ReddTigger's Avatar
There is a lot of people who weld and jb weld ports. The jap bikes typically benefit from smaller higher velocity ports, since they're turning much higher rpms then Harley's.. however, because something works in a water cooled high rpm motor, doesn't mean it will work in an air cooled torque monster..
States I've Ridden in
71.3 hp 70.8 tq
Bob s hog's Avatar
Bob s hog Bob s hog is offline
Sportster/Buell Model #2: 1200 xl sportster custom
Sportster/Buell Year #2: 03
Other Motorcycle Model: 1200 low sportster
Other Motorcycle Year: 06
Bob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to behold
sorry jordan5150 but you would be supprised how much that is yoused in porting and it works great .
Jordan5150's Avatar
Hmm, never thought of how it could benefit a jap motor, I doubt it would do much for our motors though. Have to make sure the jb weld sets properly because a chunk coming loose would be bad new bears for your motor.
I have seen shops use the JB weld with okay results but I have also seen it break off and get sucked into the engine which can be a very bad thing. At NRHS we only TIG weld if we want to add material. We NEVER use JB weld!
Jörgen Jörgen is offline
Bike Builder
Sportster/Buell Model: S&S XL124" streettracker
Jörgen has a reputation beyond reputeJörgen has a reputation beyond reputeJörgen has a reputation beyond reputeJörgen has a reputation beyond reputeJörgen has a reputation beyond reputeJörgen has a reputation beyond reputeJörgen has a reputation beyond reputeJörgen has a reputation beyond reputeJörgen has a reputation beyond reputeJörgen has a reputation beyond reputeJörgen has a reputation beyond repute
Harley evo heads are very sensitive on the short radius. It is not uncommon to increase the short radius with high temp epoxy when porting. But it has do be done correctly.
that is what NRHS does (especially S&S heads) but we TIG weld them instead of epoxy as I said. I have a very nice pulse welder just for this purpose.
Bike Builder
I agree. I like welding a lot better. Especially on these aircooled heads.
Since the exhaust often needs to be welded, why not use the same method on the intake.
