0 2003 1275 BFH 120hp still pings when going full throttle
0 new dude
Last Post: The Doctor71
Last Post: bill smith
Last Post: thefrenchowl
0 removing clear coat on fork lowers
0 15 min rides
0 Need help picking new mufflers
0 48 O2 sensor?
0 June 6th, 2020: Ironhead Rider's Gathering, PA/NJ (Spring 2020 G.B.B)
Last Post: brianbbs67
0 Help me with the physics of the Bendix float
0 Battery melt down
Last Post: sdsbassist
0 harbor freight lift
Last Post: Kbetts
Last Post: PetesPonies
0 Starting issues (No Spark)
0 73-84 big twin rear wheel
Last Post: einheit 13
0 Howdy ya'll
0 Common ironhead problems
0 back to factory clutch
0 My blow through turbo XL1200C
ken_in_il (60), big andy (56), RogueFTW (54), higdon1200 (49), sastchimo (48), NUcadet12 (42), jswoperator (40)
Old 17th February 2020
DitchTBHSMM DitchTBHSMM is offline
Sportster/Buell Model: XL
DitchTBHSMM is an unknown quantity at this point
Default Clunking into 1st after Clutch is engaged and shifter is pressed
2003 with original 5 speed transmission, new clutch cable by Terry Cable, non-synthetic primary fluid, and Energy One Clutch with 15% spring plate.
50% of the time that I go from neutral to 1st gear, when I pull in the clutch and shift into 1st, the transmission does not go into 1st. It feels/sounds like it actually goes into 1st a second or two seconds later, or as I start to release the clutch. This does not happen every time. The rest of the gears work just fine, and the bike rides fine. This happened before and after I installed the Energy One clutch plates. Any help?
Did you check the shifter adjustment when you had the Primary open?
Here's the Sportsterpedia comment & Link:
http://sportsterpedia.com/doku.php/t...e_the_trapdoor
Be sure to carefully adjust the shifter pawl as outlined in the factory service manual. This procedure is critical to center it's travel of movement to create accurate gear shifts. You must use a #32 drill bit for accuracy - no other size works properly.
http://xlforum.net/forums/showthread.php?threadid=29016
See Page 6-33/34 in the 2003 FSM...
Did you correctly adjust the Clutch Release & the new Clutch Cable adjuster links? Does the clutch drag at all (like it wants to pull the bike forward even when the clutch lever is fully pulled against the grip)?
Old 18th February 2020
bustert bustert is online now
lazy or firm shift?
sometimes, what you get is windup clunk and is normal.
Old 19th February 2020
thank you will review
