0 Superlow XL1200T tyres.
Last Post: lucifer_mr2
0 Worst Harley rider ever.
Last Post: crazyphuzz
Last Post: JacksBrother
0 Lots of issues 78
Last Post: Mrhorn12
0 New to the Harley Brand
0 What's your helmet?
0 Yetman drag frame
Last Post: Slojoe55
0 C.O.B.B run west
Last Post: Yakcm2
0 Shovester Sighting
0 1998 Sportster Ignition Problems
Last Post: james69
0 Starter circuit without relay
Last Post: ChicagoSlim
Last Post: kk38k
0 I finally learned how to work the system!
Last Post: Ranchero50
0 Broken exhaust stud questions.
0 What coil(s) do you run with your Dyna S ignition?
Last Post: stanroyal
0 Carb
0 Issue until up to temp
0 1981 XLH turns over won’t start
5 Legendary Jerry Branch on Gearing quote and question...
Last Post: groovemeisterus
0 77 idling
Last Post: fbroos73
6 Asgardia Regional area
0 Sportsterpedia Progress
View Poll Results: What synthetic oil brand do you use in your cars or your bike. You choose more than 1
Amsoil 333 24.59%
Mobil1 525 38.77%
HD SYN3 287 21.20%
Royal purple 56 4.14%
Shell 15 1.11%
Castrol 81 5.98%
Penziol 11 0.81%
Other 199 14.70%
Multiple Choice Poll. Voters: 1354. You may not vote on this poll
  #371
Old 31st May 2018
jammantoo's Avatar
jammantoo jammantoo is offline
foot in mouth member
Sportster/Buell Model: 48
Sportster/Buell Year: 2016
Other Motorcycle Model: Dou-glide
Other Motorcycle Year: 63
jammantoo has a reputation beyond reputejammantoo has a reputation beyond reputejammantoo has a reputation beyond reputejammantoo has a reputation beyond reputejammantoo has a reputation beyond reputejammantoo has a reputation beyond reputejammantoo has a reputation beyond reputejammantoo has a reputation beyond reputejammantoo has a reputation beyond reputejammantoo has a reputation beyond reputejammantoo has a reputation beyond repute
Originally Posted by Bone View Post
Google suggests you're right, 5 qts and one hole in the vrod supplies everything.
Wonder if Street is the same. Edit, looks like it is, though the volume is lower.
is the street a dry sump?
I think, and I say I think.....the reason we do not share the oil with the tranny is because we have a dry sump.
mc trannies traditionally use the gears to throw oil up and contact to each other to spread oil around. It is a vary simple and effective way to spread the oil in a system such as a geared transmission, engines need pumps to get oil up to the top end, once there the engine oil is directed where to drain by design of oil passages, plus they also shoot oil like under pistons to help cool them.
so I wonder if the Street engine is a dry sump. if it is a wet sump then there is no reason for separate oils as long as the tranny is in the same case.
Join the PEANUT CLUB, it gives you an excuse to stop and smell the roses
Old 1st June 2018
Bone's Avatar
Bone Bone is offline
Sportster/Buell Model: 1200Lr
Sportster/Buell Year #2: 2016
I didn't look that close, but assume both the Vrod and Street are probably wet sump.
And yes most manual transmissions are splash lubricated, but there are exceptions. The late-model Guzzi smallblocks with the 6-spds come to mind. They're wet sump motors with dry automotive style clutch and a separate PRESSURIZED transmission with it's own oil source and pump.
But your logic might be why Harley initially went with separate engine and drive fluids on most of their bikes.
Old 1st June 2018
Sportster/Buell Year: 2018
Tucsonmax1 is an unknown quantity at this point
I owned a Street 750. They are Wet sump. Having only 1 drain plug for the Oil. I thought it was better. Since the Oil is getting Filtered.
Tucsonmax1 2018 Sportster 1200 Custom, 2016 Hyundai Tucson SE AWD
Old 1st June 2018
hexnut's Avatar
hexnut hexnut is offline
Sportster/Buell Year: 2014
Early Sportsters had a dry clutch as did the big Harleys. I believe the big bikes went to wet clutch around 1984. They had some oil in the primary for the chain only. My old 1964 Pan had a total loss primary chain oiler. There was a hole in the bottom of the primary cover as I recall.
Tuned by Power Vision
Supertrapp Supermegs exhaust
1200 gearing, super brace
Old 2nd June 2018
ironmanx ironmanx is offline
Sportster/Buell Model: XL883L
ironmanx is an unknown quantity at this point
Penrite V-Twin 20W-50 PAO Ester for the HD
Nulon 10W-40 Full Synthetic for my 1MZ-FE Camry
jammantoo's Avatar
re correct, my 63 Pan is like that.
Part of the old saying Harley's mark there territory is not because they leaked oil, it is because they had systems that were leaks on purpose, like chain oilers.
60Gunner's Avatar
60Gunner 60Gunner is offline
60Gunner has a brilliant future60Gunner has a brilliant future60Gunner has a brilliant future60Gunner has a brilliant future60Gunner has a brilliant future60Gunner has a brilliant future60Gunner has a brilliant future60Gunner has a brilliant future60Gunner has a brilliant future60Gunner has a brilliant future60Gunner has a brilliant future
Well since it was dug up, I'll chime in. No synthetic here. Especially not in the primary.
Valvoline vr1 20w50 racing oil. Drag Specialties Gear and Chaincase oil in the primary. Equivalent to HDs Sports-Trans no longer available.
05 1200C w/custom timing map 'VooDoo'
Dragtron II/K&N filter/Cycle Shack pipes/HP+baffles
45/175/N65C shimmed .040/ICM 1-3/4 turns
Ridneck1986's Avatar
Ridneck1986 Ridneck1986 is offline
Sportster/Buell Model: 883l/1200
Ridneck1986 is an unknown quantity at this point
Red line here. No problems at 35k on her
05 883l-1200
