0 Superlow XL1200T tyres.
Last Post: lucifer_mr2
0 Worst Harley rider ever.
Last Post: crazyphuzz
Last Post: JacksBrother
0 Lots of issues 78
Last Post: Mrhorn12
0 New to the Harley Brand
0 What's your helmet?
0 Yetman drag frame
Last Post: Slojoe55
0 C.O.B.B run west
Last Post: Yakcm2
0 Shovester Sighting
0 1998 Sportster Ignition Problems
Last Post: james69
0 Starter circuit without relay
Last Post: ChicagoSlim
Last Post: kk38k
0 I finally learned how to work the system!
Last Post: Ranchero50
0 Broken exhaust stud questions.
0 What coil(s) do you run with your Dyna S ignition?
Last Post: stanroyal
0 Carb
0 Issue until up to temp
0 1981 XLH turns over won’t start
5 Legendary Jerry Branch on Gearing quote and question...
Last Post: groovemeisterus
0 77 idling
Last Post: fbroos73
6 Asgardia Regional area
0 Sportsterpedia Progress
jonesboy jonesboy is offline
Sportster/Buell Model: Ironhead sportster
jonesboy is an unknown quantity at this point
Default 40mm s e keihin carb
I have read the carb thread by the way but there's not much on the screamin eagle. I bought this on eBay as I was having bother with the standard butterfly keihin.
Is this too big for my '78 sportster, it ran but too rich low down I couldn't sort it with the. Mixture screw, the idle jet is 68. Does anyone know what jetting to try, main is a 160 , the bike has standard looking silencers and standard air filter.
I have since got my standard carb working ok but would like to still try this one,I like the pull up choke.
If the answer is bin it then fine, any advice appreciated
If it's the SE model, I expect it is a 44mm venturi --- I don't think there was a SE 40mm...
Unless you have the engine worked, the 44mm is overkill... That doesn't mean it should end up in the trash bin - You could probably re-sell it and get a standard Keihin CV40 carb that matches better to your motor...
2 Relax
Thanks for the reply , the Venturi measured with callipers is 40mm but rhea butterfly is 46 mm, still big though
Yep - You're right - I went back to a 1992 Accessories Catalog and found in the Racing Section that there was a 40mm SE Carb Kit (not CV) ... 29081-90A...
The stock jets were:
.68mm - Slow Jet
.60mm - Intermediate Jet
1.60mm - Main Fuel Jet
Blank - Intermediate Air Jet (but could be changed)
So that might be usable...
Does it have the two-bolt flange mount? There is mention of needing the older style manifold - 27004-86 - for installation on '88-'92 models...
2 Relax
Since SE didn't make carbs it would be best to post a pic or two of the carb so we can ID it. It could be a Kehin or a Mikuni or some bastard love child reincarnation of the QuickSilver or some such POS.
Here's a PDF from Chris Hajer on the 29081-90C...
http://www.chrishajer.com/bike/XLF/29081-90C.pdf
2 Relax
man haven't heard the term quick chicken in awhile. weren't that great.
That's it in your link IXL , with the flange mounting too, I may try again with a smaller idle jet as it seems worst about 1/4 throttle , idle jets are available easily too same as the other keihins , thanks
