0 Rear Brake Squeal Fixed
0 Rocker Arm Acorn Nut Torque Problems..
Last Post: Flam
0 Informed reviews!
Last Post: staniel
0 R.I.P.Meat Loaf
Last Post: deguireb
0 my motorcycle trailer (goes down flat, comes back up)
Last Post: adri
0 Allegheny National Park III
0 1980 Shovelhead WideGlide
0 Speedometer
0 Primary thread
Last Post: RandallM
0 weight loss thread
0 Dyno Test Results: W Cams versus D Cams
Last Post: Jonny48
0 2022 Sportsters
Last Post: Edster
0 LED Smoked Turn Signals (Arlen Ness & Custom Dynamics)
Last Post: cbzdel
Last Post: wrkdWS6
0 Video - Dyno Numbers are NOT What We Look For!
0 1995 Manual
Reynoldston (81), showmebandit (68), Hoppy1313 (68), FredrikK (66), Toejam503 (66), YO MUDA (63), Altopass (62), tim 2007xl1200c (55), w9awx (49), 3xtrastout (43)
clutch slips primary lube
Old 21st March 2021
rejeanprimeau's Avatar
Originally Posted by rwharris View Post
How about Bel Ray sports trans fluid? Would that be a decent oil?
Yes made for Sportster, they must know what it's good for your Sportster.
Old 21st March 2021
Steve9's Avatar
Steve9 Steve9 is offline
Sportster/Buell Model #2: XL
Other Motorcycle Model: FXDC
Works well in mine. Bel ray
Steve
'01 Cyclone
'13 FXDC 96" stock
Old 21st March 2021
CCC CCC is offline
Sportster/Buell Model: 1200S Sport
CCC is a name known to allCCC is a name known to allCCC is a name known to allCCC is a name known to allCCC is a name known to allCCC is a name known to allCCC is a name known to allCCC is a name known to allCCC is a name known to allCCC is a name known to allCCC is a name known to all
Here's a mind blower cross reference that gear oil and see what weight engine oil it is. Don't fall victim to the BS man
Old 20th October 2021
Fifty150's Avatar
Fifty150 Fifty150 is offline
Sportster/Buell Model: XL883L
Fifty150 has a brilliant futureFifty150 has a brilliant futureFifty150 has a brilliant futureFifty150 has a brilliant futureFifty150 has a brilliant futureFifty150 has a brilliant futureFifty150 has a brilliant futureFifty150 has a brilliant futureFifty150 has a brilliant futureFifty150 has a brilliant futureFifty150 has a brilliant future
Mercon V has been good to my crown vic, 155,000 miles on that trans.
I think that the Crown Vic has a transmission which specifies the use of Mercon V. In which case, Mercon V is what you are suppose to use.
I have been using Mercon V in my primary case.
Old 21st October 2021
Sportster/Buell Year #2: '03
from memory 90w gear oil=sae 50w motor oil.i'm still not comfortable with that.have you smelled 90w gear oil?it's nothing like 50w motor oil.
