0 Rear Brake Squeal Fixed
0 Informed reviews!
Last Post: 2cam
0 Primary thread
Last Post: JimVonBaden
Last Post: Edster
Last Post: ZTatZAU
Last Post: Jhbox13
Last Post: Randy_rots
0 Oil system prime
0 1971 with a Mag
Last Post: Whitewalls
0 1977 xlh
0 Nicks custom cycle
0 old school prism oil filter/cooler
Last Post: 73HEAD
0 Regulator test 1974 xl
Last Post: Jaime1840
0 Allegheny National Park III
0 WTB--shocks
Last Post: Doc308
0 Digital volt meter
  #771
Old 22nd October 2021
handa700 handa700 is offline
Sportster/Buell Model: 1200 Roadster
handa700 is an unknown quantity at this point
Default 04 Roadster problems
None. Just get rid of the stock suspension pieces, jet the carbs right, keep up regular maintenance, and this bike will last at least 100,000 miles.
dk1six's Avatar
dk1six dk1six is offline
Sportster/Buell Model: 883L
Sportster/Buell Year: 07
Sportster/Buell Model #2: BMW K1600 GT
Sportster/Buell Year #2: 19
Other Motorcycle Model: Ducati S2R
Other Motorcycle Year: 05
dk1six is a name known to alldk1six is a name known to alldk1six is a name known to alldk1six is a name known to alldk1six is a name known to alldk1six is a name known to alldk1six is a name known to alldk1six is a name known to alldk1six is a name known to alldk1six is a name known to alldk1six is a name known to all
I've had a failing battery that almost stranded me but my 07 with 9,454 miles has been very dependable when I do ride it. Funny thing is, I bought it on a whim in 2011 pulled into Boston Harley Davidson one day just driving by and ended up buying it before I left.
Since then I've had six other bikes I've added to my collection all unique that I bought thinking I'll keep this forever and just recently I sold three bikes to try something new.
The HD is still here after all the buys and sells and with no intentions to let it go. Love the Sportster it's a cool easy to ride bike, there's something guttural about it that a lot of brands don't come close to.
But yeah it's always been dependable
diver diver is offline
Sportster/Buell Model: 1200c
Other Motorcycle Model: ST1100 Pan Euro
Other Motorcycle Year: 2000
diver is a glorious beacon of lightdiver is a glorious beacon of lightdiver is a glorious beacon of lightdiver is a glorious beacon of lightdiver is a glorious beacon of lightdiver is a glorious beacon of lightdiver is a glorious beacon of lightdiver is a glorious beacon of lightdiver is a glorious beacon of lightdiver is a glorious beacon of lightdiver is a glorious beacon of light
I've had mine since 2009 and a few years ago it started ok but run like crap and kept on cutting out. A new battery was all it needed. When it was still new, the imobiliser thingy failed and one of the exhaust pipe header bolts fell out as did one of the engine brace bolts. Since then it has been as good as gold (touch wood).
Paul
Paul-Manchester England
Running V&H 3" slash cut slip ons and SE stage 1 A/C. All helped along with a Kitech Fueller. Did it myself - sod the dealer
duffy duffy is offline
Sportster/Buell Model: Anniversary 883 Hugger
Sportster/Buell Model #2: 03' Sportster 883 Hugger
duffy has a brilliant futureduffy has a brilliant futureduffy has a brilliant futureduffy has a brilliant futureduffy has a brilliant futureduffy has a brilliant futureduffy has a brilliant futureduffy has a brilliant futureduffy has a brilliant futureduffy has a brilliant futureduffy has a brilliant future
I've had mine over two years and about 10K miles with no problems except tires and a battery.
Ghostdog's Avatar
Ghostdog Ghostdog is offline
Sportster/Buell Model: Sportster iron 883>1275
Sportster/Buell Year: 2016
Ghostdog has much to be proud ofGhostdog has much to be proud ofGhostdog has much to be proud ofGhostdog has much to be proud ofGhostdog has much to be proud ofGhostdog has much to be proud ofGhostdog has much to be proud ofGhostdog has much to be proud ofGhostdog has much to be proud ofGhostdog has much to be proud ofGhostdog has much to be proud of
Originally Posted by Roug_04 View Post
Just one in 2007, cover on the crank pisition sensor busted on me when i was stationed in SC. I was hot dogging to Savannah harley bike got hot and when metal gets hot it expands crank slapped the sensor. No worries easy fix harley repaired it under warranty. Well 3yrs same month and almost the same dayit happens again. Come to find out they made the crank position sensor to long and the fix was to space it out by .035 from the case by washer(s). So I replaced it myself $65.00 dollars and some time flushing the oil system i have had no other problems. Not sure when harley may have corrected this but if you have a 04 and later you ,might want to ask.
This is the first time I’ve herd or read about this issue with the crank position sensor being to long and needing a spacer. I have a 2016 iron myself . I’m wondering if anyone has any more information on this type of problem and what year or years sportsters were or are plagued by this issue? Anyone have any more info on this at all??? Please share as it could help people out in the future. Thank you Roug_04 for posting this issue and your experience.
Ghostdog 2016 iron883<1275 Hammer prefomance kit, energy one extra plate clutch, 15percent spring,N4 cams, ported 883 heads ,danmoto 2-1 exaughst ,Dynojet powervision tuner .
andy2175m4 andy2175m4 is offline
Sportster/Buell Model: Ironhead XLS
Sportster/Buell Year: 1979
Sportster/Buell Model #2: XLS
Other Motorcycle Model: Suzuki Norton BMW Yamaha
Other Motorcycle Year: 70's
andy2175m4 is a splendid one to beholdandy2175m4 is a splendid one to beholdandy2175m4 is a splendid one to beholdandy2175m4 is a splendid one to beholdandy2175m4 is a splendid one to beholdandy2175m4 is a splendid one to beholdandy2175m4 is a splendid one to beholdandy2175m4 is a splendid one to beholdandy2175m4 is a splendid one to beholdandy2175m4 is a splendid one to beholdandy2175m4 is a splendid one to behold
I have an 81 AMF sportster, the carb was a bit tacky but after I replaced that, no problems. works fine.
Welcome back my friends to the show that never ends!
Ironhead Max Ironhead Max is offline
Sportster/Buell Year: 1981
Other Motorcycle Model: Triumph,Suzuki,Yamaha
Other Motorcycle Year: Old
Ironhead Max is a splendid one to beholdIronhead Max is a splendid one to beholdIronhead Max is a splendid one to beholdIronhead Max is a splendid one to beholdIronhead Max is a splendid one to beholdIronhead Max is a splendid one to beholdIronhead Max is a splendid one to beholdIronhead Max is a splendid one to beholdIronhead Max is a splendid one to beholdIronhead Max is a splendid one to beholdIronhead Max is a splendid one to behold
I've had my 81 since new and have had no major problems and one small problem was caused by me from putting an aftermarket coil on when there was no problem with the factory unit.
Crusty Crusty is online now
Sportster/Buell Year #2: 1978
Other Motorcycle Model: XL 1200 C
"If it has wheels or tits, it will eventually give you problems."
True words.
