0 ironhead oil pump pressure
0 is a buell a harley
0 Spokes or Mags
Last Post: d10221
12 Remember the Fallen
0 ‘72 Pinion gear question
Last Post: NP72Iron
0 Sidestand Extension/'Pad' ?
0 Burly Stilletto 13" shocks or ?
0 Upgrade carb kit
Last Post: 80HDXLS
0 When Were You Born?
Last Post: jimmyess333
0 Show me your plugs
0 Massachusetts 2022
0 Mid or forward controls.
Last Post: lostNdallas
0 ‘72 IH…early or late ‘72?
Last Post: NP72Iron
0 Changed The Fork Oil
0 New guy
0 1999 S upgrades
Last Post: lou
Mr. Lynn (76), dentat2 (52), OWNED13 (49), knolan.smith (44), Malicious44 (37)
  #61
Old 23rd October 2021
Jaime1840 Jaime1840 is offline
Sportster/Buell Model: XL
Sportster/Buell Year: 1974
Jaime1840 is a glorious beacon of lightJaime1840 is a glorious beacon of lightJaime1840 is a glorious beacon of lightJaime1840 is a glorious beacon of lightJaime1840 is a glorious beacon of lightJaime1840 is a glorious beacon of lightJaime1840 is a glorious beacon of lightJaime1840 is a glorious beacon of lightJaime1840 is a glorious beacon of lightJaime1840 is a glorious beacon of lightJaime1840 is a glorious beacon of light
Originally Posted by Fivecats View Post
Its lean... needs some gas thrown at it. The idle jet needs bumped up some, along with the adjustments for a 1k idle. Did the throttle cable reroute work?
Nice looking bike
Thanks man, yes the cable reroute worked fine. I will adjust the mixture screw tomorrow but I think I will have to change jets.
the fact that it currently has no filter element could be contributing to this.
That's what I tought, I think that the jet set up on this carburetor it's not working well how the bike is now
Do you guys think it could run the bike like this ( adjusting the mixture a bit) or it could cause serious damage to the engine? How can I really tell that it's overheating? Thanks
Ferrous Head's Avatar
Sportster/Buell Year #2: 1966
I really like how it turned out but its very sketchy to ride with no front brake and the springer front end Im trying to dial in the rear brake but for the moment it´s not doing much
"Your a braver man than I am, Gunga Din."
No air filter and drags will make it run lean. Yes, you can damage the engine by letting it overheat from running too lean.
Old 24th October 2021
Steve9's Avatar
Steve9 Steve9 is offline
Sportster/Buell Model #2: XL
Other Motorcycle Model: FXDC
I believe the motor runs hotter during break-in. But lean for sure will create heat
Steve
'01 Cyclone stock
'13 FXDC 96" stock
Any recommendations on jetting the Keihin CV carb? I'm going to run an aftermarket air filter with not necessarily more air flow than the OEM one, but it's the one that came with the bike and baffled drag pipes. If I remember correctly right now I have a 46 pilot and a 175 main.
72HOGXLCH 72HOGXLCH is offline
Sportster/Buell Year: 1972
72HOGXLCH is an unknown quantity at this point
Is it best to use a straight weight oil such as 40 or 50 with no detergent? Use to swear by this on my old car engine rebuilds.
