0 Rear Brake Squeal Fixed
0 Informed reviews!
Last Post: 2cam
0 Primary thread
Last Post: JimVonBaden
Last Post: Edster
Last Post: ZTatZAU
Last Post: Jhbox13
Last Post: Randy_rots
0 Oil system prime
0 1971 with a Mag
Last Post: Whitewalls
0 1977 xlh
0 Nicks custom cycle
0 old school prism oil filter/cooler
Last Post: 73HEAD
0 Regulator test 1974 xl
Last Post: Jaime1840
0 Allegheny National Park III
0 WTB--shocks
Last Post: Doc308
0 Digital volt meter
View Poll Results: Best carb for reliable daily use
S&S 166 31.14%
Mikuni 101 18.95%
CV 166 31.14%
Bendix 57 10.69%
SU 16 3.00%
Other 27 5.07%
Voters: 533. You may not vote on this poll
  #221
Old 25th October 2021
mikethebike61's Avatar
mikethebike61 has a reputation beyond reputemikethebike61 has a reputation beyond reputemikethebike61 has a reputation beyond reputemikethebike61 has a reputation beyond reputemikethebike61 has a reputation beyond reputemikethebike61 has a reputation beyond reputemikethebike61 has a reputation beyond reputemikethebike61 has a reputation beyond reputemikethebike61 has a reputation beyond reputemikethebike61 has a reputation beyond reputemikethebike61 has a reputation beyond repute
Originally Posted by chrishajer View Post
'79 had a Keihin fixed venturi (butterfly, non-CV.) If I were picking a carb for an ironhead, I would pick a CV because takeoffs are cheap and plentiful, parts are cheap and plentiful and it works pretty well all the way around. If I had to rank them:
  1. CV
  2. Stock Keihin (new, not worn out)
  3. Mikuni HSR42 or HS40 (more $$ than CV, better throttle response than S&S)
  4. S&S E (more $$ than CV)
  5. Bendix (new, not worn out)
  6. SU (really don't like these, the original CV )
Worst problem is the stock petcock location on older ironheads interferes with the RTI cable bracket forcing you to either change tanks or cut the bracket and not run an RTI cable.....which leads to the problem of the engine not reliably returning to idle...
Anyone know of an aftermarket bracket that allows you to use the stock tank?
--Chris
I could be wrong....I'll ask the wife....she ALWAYS knows when I'm wrong......
Old 26th October 2021
Originally Posted by Iron Mike View Post
back to OP
.....I run VM Mik's when straying from stock carb. Easily tunable, consistant , inexpensive and reliable. Have run Bendix, Su, DelOrto, S&S, Keihin CV all with decent results.
Nobody wants to hear that...too simple....too true...some MUST have a villain and in my 50+ years on these things the LAST OEM carb before a change is the bad guy....
