0 High beam not working
Last Post: Jaime1840
0 Massachusetts 2022
Last Post: ZTatZAU
0 "S" model specific Q&A
Last Post: heyjames
0 Video - MOST Power Increase Per Dollar Spent - PROVEN!
0 Crocker custom
Last Post: friday
0 Informed reviews!
Last Post: rocketnorton
0 gasket sealant
Last Post: 11B40
0 Sportster Tracker Wheel and Tire Questions
0 weight loss thread
Last Post: JimVonBaden
0 Primary thread
Last Post: RandallM
Last Post: 11B40
Steph (56), yubman (51), Sporty1971 (51), Windesch (49), Mark_Bench (45), motherduce (43), sgtfry (40), Mrtechit101 (31)
no oil flow rear rocker
Old 26th October 2021
Ferrous Head's Avatar
Sportster/Buell Year #2: 1966
These oil passages are quite small and the oil pump doesn't really produce all that much pressure.
So, something blocked an oil passage. Possibly (probably) had to get passed the oil feed gears to get up there. So, small solid particles. Hmmmmmn. What could that be ?
If it were my bike I would want to know.
If you haven't recently you should consider dropping the oil and looking for particles. In this case, most likely the nice shiny silver ones. The nice golden ones never get that big and they dull grey ones don't wither.
But those little hard shiny ones ?
Old 27th October 2021
Glad you got it solved.
But I'm with Ferrous Head, I'd like to know what was blocking it up.
Sportster/Buell Year #2: '03
i don't really consider any of those particles as''nice.''
The lack of a comma between "nice" and the second adjective means this is a cumulative adjective. So, the particles aren't "nice" but the color is.
And when you see that nice, gold metal-flake, black oil in your oil pan don't you wish you could paint your bike that color ?
Old 28th October 2021
IronMick's Avatar
IronMick IronMick is offline
Rider Of The Iron Steed
The lack of a comma between "nice" and the second adjective means this is a cumulative adjective...
Well, I thought I knew all of the English language minutiae, but the "cumulative adjective" is new terminology to me
Mick
IronHead Forever!
Visit Mick's WebSite
[And Check Out My Autobiog]
IronHeadRon IronHeadRon is offline
Sportster/Buell Year: 1969
Other Motorcycle Model: Honda Shadow
Other Motorcycle Year: 1986
IronHeadRon is an unknown quantity at this point
You cleared something out of somewhere, I hope it didn't end up somewhere worse though. Is this a known method? How did you think of it, if the clog was below the lines? Anyways, that's awesome that it worked, I would consider a kerosene flush if I were you (I know it's a hot subject but I dont see why, it's right in the manual in the service after 500 section "flush with kerosene through drain plug" (I use return line though, drain plugs scare me on motercycles)
Edit: I didn't see 2nd page. I'm sure it's better advice than mine, but I'll leave it because it did help our bike and flushed quite a bit of gunk out (enough to clog the puke tube until a good kick at one point)
Obviously tearing in and finding the culprit would be satisfying, but that's a lot to do. Maybe I am lazy, but I also recently had the covers and jugs off so I knew what I could see was clean. Should've gone through it all with air, but didn't think of it at the time.
That's nothing, go to Tennessee and they have no idea what a "crap load" is.
The English language is in fact, quite complex and nuanced. It's how lawyers and politicians earn their living. You'll find that very often, politicians are also lawyers. One of their most basic skills is to understand and know how to manipulate the English language.
It's why we hate them so much.
"The pen is mightier than the sword"
Steve9's Avatar
Steve9 Steve9 is offline
Sportster/Buell Model #2: XL
Other Motorcycle Model: FXDC
Si.
Too few characters
Steve
'01 Cyclone
'13 FXDC 96" stock
