0 Rocketmangb
Last Post: seajay
0 carb needle replacement procedure
0 Tank flush
0 Getting old is a bitch!
0 85 Ironhead, Kiffy Stand Question
Last Post: eddie XLX
0 Turn signals stopped blinking
Last Post: RandallM
0 Allegheny National Park III
Last Post: skien
0 Clutch Replacement
0 My new deer rifle
Last Post: kiwicafesporty
Last Post: 11B40
Last Post: speedyrette
4 Sportster ignition/vacuum/carb/fuel/electrical issues?
Last Post: shtbskt
Last Post: Brad
0 Sportster S on the dyno
Last Post: Fivecats
0 1967 on FaceBook. Florida.
0 High beam not working
Last Post: joe s
5 Best way to ship large parts?
77xlch, buell_fxr (76), Danny (65), Wino (53), mucas859a (48), no_chrome (47), USMC_Davii (45), dijitaldna (40), 08nightmare
Old 30th September 2021
gary59 gary59 is offline
Sportster/Buell Model: 883
gary59 will become famous soon enoughgary59 will become famous soon enoughgary59 will become famous soon enoughgary59 will become famous soon enoughgary59 will become famous soon enoughgary59 will become famous soon enough
Default Need to Replace Ignition Module
I need to replace the ignition module on 98 883. Should I buy Harley or aftermarket? If aftermarket provide a link. Surdyke harley is $211.24
Here's the HD Screamin' Eagle & other aftermarket ignition module page in the Sportsterpedia. There are other modules available, but the most popular around this forum is the Ultima nosecone ignition.
http://sportsterpedia.com/doku.php/t...k:ref:engctl01
The original HD modules were very susceptible to heat failures. HD quit making them very shortly after the 2003 models, the last that took the nosecone modules.
For Sportster Tech Info:
Fivecats's Avatar
Fivecats Fivecats is offline
Sportster/Buell Year: '68
Sportster/Buell Model #2: FXR
Sportster/Buell Year #2: '89
Other Motorcycle Model: R50/5
Other Motorcycle Year: '73
Fivecats has a reputation beyond reputeFivecats has a reputation beyond reputeFivecats has a reputation beyond reputeFivecats has a reputation beyond reputeFivecats has a reputation beyond reputeFivecats has a reputation beyond reputeFivecats has a reputation beyond reputeFivecats has a reputation beyond reputeFivecats has a reputation beyond reputeFivecats has a reputation beyond reputeFivecats has a reputation beyond repute
Are you sure its the module... I just replaced the ignition only to realize the coil was bad, even the new one. You tube has got info on checking the coil, its simple.
https://www.youtube.com/watch?v=Y8n1fBkDaCQ
The coil tested okay. I followed the repair manual procedure.
I am getting a backfire while cruising so I am going to replace the ignition module with a new harley module. It should be plug n play as long as I put a scribe mark where the old module mounted to the backing plate.
Old 18th November 2021
Just an update....my dealer matched the 211.00 price and the part did fix the backfiring.
Old 19th November 2021
Thanks for the 'end-of-the-story'...
Glad you got it fixed and running properly...
vom is a go/no go test at best, it cannot really tell much else. there is error within the meter itself and the type of coil under test makes a huge diff.
