0 Putting the Sport back in the Sportster
Last Post: 1Scooter
0 Latest toy arrived... 1967 Sportster XLB
Last Post: boonoorong
Last Post: Sportster25
0 Chain: What Type?
0 shovster ignition timing
0 A few Thoughts
Last Post: Monte03
0 Cams for a Turbo XL1200H
Last Post: casual_obser
0 What's Wrong With My Bike
Last Post: PoodlePunche
0 Through The Years
0 A year later...
Last Post: Andy56
Last Post: gconnsr
0 trimmed shovel top hats
0 Amazon CV carb
0 Belt tension
Last Post: Bryan1976
0 Ignition circuit
0 Pipes "Wheezing" on decel
0 Buell XB top end on Sportster Who has Done It??
Last Post: Racepres
0 distributor
0 Rear pulley inner flange
breakwind, OkieHD1911 (73), Sal77 (68), Jeffro (52), NYSPORTY (47), lordharley (46), gearzslyb (29)
  #201
Old 10th January 2022
sungod's Avatar
sungod sungod is offline
Sportster/Buell Year: 1970
Sportster/Buell Year #2: 73
The light comes on to keep me from freezing in my shop. It is 27 today.
Old 12th August 2022
thefrenchowl's Avatar
Sportster/Buell Model: KHK
Sportster/Buell Year: 1954
Sportster/Buell Model #2: 900cc XLB
Sportster/Buell Year #2: 1967
Other Motorcycle Model: 1200cc XLRTT
thefrenchowl has a reputation beyond reputethefrenchowl has a reputation beyond reputethefrenchowl has a reputation beyond reputethefrenchowl has a reputation beyond reputethefrenchowl has a reputation beyond reputethefrenchowl has a reputation beyond reputethefrenchowl has a reputation beyond reputethefrenchowl has a reputation beyond reputethefrenchowl has a reputation beyond reputethefrenchowl has a reputation beyond reputethefrenchowl has a reputation beyond repute
Hi,
Piece of construction square tubing, 4" x 2", about 10" long, with 4 bolts welded on it.
Used to set up either head on milling machine to dial up mill head to spark plug thread, then turn head on jig 180 degrees to drill/tap another sparkplug thread on right hand side.
Recently put/welded 2 studs on other side plus big clearance holes to locate crank assembly to ease tightening of big crank pin and shafts nuts.
Now, with drive side nut loose but not out, split the crank: Piece of wood on the floor, hold rods with right hand, drive mainshaft in left hand, rise about 2 feet hight and swing down while keeping rods in an horizontal alignement and stike left wheel on wood. Right wheel continues travel due to inertia and the right taper breaks...
Patrick
