0 Putting the Sport back in the Sportster
Last Post: 1Scooter
0 Latest toy arrived... 1967 Sportster XLB
Last Post: boonoorong
Last Post: Sportster25
0 Chain: What Type?
0 shovster ignition timing
0 A few Thoughts
Last Post: Monte03
0 Cams for a Turbo XL1200H
Last Post: casual_obser
0 What's Wrong With My Bike
Last Post: PoodlePunche
0 Through The Years
0 A year later...
Last Post: Andy56
Last Post: gconnsr
0 trimmed shovel top hats
0 Amazon CV carb
0 Belt tension
Last Post: Bryan1976
0 Ignition circuit
0 Pipes "Wheezing" on decel
0 Buell XB top end on Sportster Who has Done It??
Last Post: Racepres
0 distributor
0 Rear pulley inner flange
breakwind, OkieHD1911 (73), Sal77 (68), Jeffro (52), NYSPORTY (47), lordharley (46), gearzslyb (29)
Old 11th August 2022
gotamotor gotamotor is offline
Sportster/Buell Model: Xlh
gotamotor is an unknown quantity at this point
Default Primary cover screws... Washers??
My cover as far as I know has never had washers for the primary cover screws.
Is this how it should be?
I notice there are indentations in the case from tightening the bolts down.
Tightening too tight?
Thinking of looking for some small copper or brass washers for them all. Notice a leak coming from on of the bottom bolts.
Also having issues preventing my Transmision drain plug from not leaking.
Threads seem okay although maybe worn, i was afraid i may have stripped it after trying to use a rubber o-ring and maybe tightend too much. In all honesty some aluminim came out this morning when i took the plug out. But I can screw the bolt in by hand and apply tightness.
I'm thinking for the drain plug( depending what I can find at my local hardware) of either, ideally a copper crush washer and then some kind of sealant. Or a paper gasket of some sort and some sealant.
And recommended sealant?
Thoughts?
Monte03's Avatar
Monte03 Monte03 is offline
Sportster/Buell Year: 1969
Sportster/Buell Model #2: 1966 XLCH
Other Motorcycle Model: BMW Twin
Other Motorcycle Year: 82
Monte03 has much to be proud ofMonte03 has much to be proud ofMonte03 has much to be proud ofMonte03 has much to be proud ofMonte03 has much to be proud ofMonte03 has much to be proud ofMonte03 has much to be proud ofMonte03 has much to be proud ofMonte03 has much to be proud ofMonte03 has much to be proud ofMonte03 has much to be proud of
7036 1/4” lock cad washers ,if XLCH they make a thicker than OEM Gasket worth the investment , Gary Bang is one name , may have to search , drain plug- I use a Loctite PST, it does not get rock hard , White in Color
Cycle World Oct 1962:
'The Sportster XLCH is not every Man's cup of tea - and we don't think it was intended as such'
Old 12th August 2022
Okay cool thanks! I got some Permatex High Temp thread sealant its similar looking to the loctite PST. Do you use a washer of any sort on your plug?
I did find that unfortunately it seems that I have damaged some of the threads for my drain plug,yikes. It won't torque down with a crush washer that I tried, but it will torque down with no washer.
I put on some tape and the permatex thread sealer and snugged it up. not sure if that's too overboard or not.
Will see if it holds, although I may have a bigger thread repair in the future, sigh.
Monte03's Avatar
IMO nothing will correct bad threads other than a proper repair, the Last thing you want to do is place a Tapered Pipe Fitting in there ‘that will surely invite a cracked case ‘, there are plugs that have a smaller plug within the larger plug, once in place you are only removing the small steel plug rather than disturbing the fragile aluminum case threads , do some research, others may chime in
Ferrous Head's Avatar
Sportster/Buell Year #2: 1966
Drain plugs.
Not sure which engine you have but early engines use a stepped brass washer. Most people ignore this special washer and install whatever they have handy.
Check the parts nook for your model/year and see if they [specify a washer. Use that one.
Andy Hog's Avatar
Andy Hog Andy Hog is offline
Sportster/Buell Year: 1981
Other Motorcycle Model: 1964 Triumph 3TA
Andy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant future
If you have access to a lathe or can find a shop that does you can get a slot milled on the underside of the head of the bolt & fit an O ring, also use plumbers tape on the thread.
I use washers on all my case bolts
Old 13th August 2022
I do have a parts manual.. sigh
72 Ironhead XLH's Avatar
Sportster/Buell Year: 72
Harley never used them, Why should you?
