0 Pictures that need no explanation... don't let this thread die!!
0 XLCH Crazy voltage spike
Last Post: MonkeyMadness
0 BETTER Brakes for $214
0 oops, my bad.
Last Post: lostNdallas
0 Front forks replace or restore
0 Flame's New 1989
0 Oil leaking under starter
Last Post: motorend
0 Wet Sump Ifo, fix and tools
0 machine work
0 DK Custom '19 Summer Adv. Riding to where Titanic Sank -Newfoundland Island & More
0 Hardtail sporty ideas
Last Post: Will1250
0 Production LiveWire
0 brake fluid
Last Post: 11alan111
Last Post: conv90
0 Battery/regualtor/charging strange problem
Last Post: conv90
Last Post: Akeemking
0 Boardtracker Project
0 **DK CUSTOM - Pro-Action Street Series Shocks**
Papatony, chedd (74), Nevar (69), nrbase (67), Smokin-Smitty (62), kbfarkas (60), Irondreads (50), Tim97509 (49), CCM0021 (48), wandrur, bikerusn5 (36)
bobber, hard tail, harley trike, ironhead, sportster trike
  #6011
wedge's Avatar
wedge wedge is offline
Originally Posted by Bigshankhank View Post
My 1980, built by who knows who.
Maybe Amen frame and tank?
HDCUSTMBUILD HDCUSTMBUILD is offline
HDCUSTMBUILD is an unknown quantity at this point
Here's a few snaps on my XL 1200 still in build. Really can't make my mind up on chopping the rear fender of fill in where the square hole where the tail light was (tail light mounted on licence plate side mount.
Sent from my SM-G975F using Tapatalk
wedge's Avatar
If I was thinking of cutting mine, I would make sure that the rooster tail flies backwards, even when going slow. (If you take a straight edge and place it against the tire holding it vertical, the limit is wherever that intersects the fender). Personally I am not fond of water running down my back and riding in a puddle. I don't run a front fender and I put up with occasionally leaning out of the way, but you just can't avoid the rear rooster tail . I can ride for hours leaning left .
Akeemking's Avatar
Akeemking Akeemking is offline
Sportster/Buell Model #2: XLX-61
Sportster/Buell Year #2: 1984
Other Motorcycle Model: XLH
Other Motorcycle Year: 1960
Akeemking is a splendid one to beholdAkeemking is a splendid one to beholdAkeemking is a splendid one to beholdAkeemking is a splendid one to beholdAkeemking is a splendid one to beholdAkeemking is a splendid one to beholdAkeemking is a splendid one to beholdAkeemking is a splendid one to beholdAkeemking is a splendid one to beholdAkeemking is a splendid one to beholdAkeemking is a splendid one to behold
Default Sporty bobber pictures
- Traditional is Timeless -
Old 6 Days Ago
Highly-Dangerous's Avatar
SPANIARD
Sportster/Buell Model: XL 883
Almost finished.....
Old 6 Days Ago
SPANIARD
Old 6 Days Ago
SPANIARD
Old 6 Days Ago
wedge's Avatar
Now, see, if you lay a straight edge against the tire and have it touch that back fender, that is the angle that water will pelt your back. At that angle you couldn't outrun the rooster tail unless you get the bike up over 373 MPH.
You will either need rubber shorts, or learn to live with diaper rash.
Looks great by the way.
Old 6 Days Ago
Lone Rider's Avatar
Sportster/Buell Model: 1200
Don't worry about the rooster tail HD if you are riding in the rain u gonna get wet.
My rooster tail maker.
