0 Boardtracker Project
5 Change Tranny Sprocket After Conversion?
0 Help removing speedo connector
Last Post: lmarshall73
0 Big Bore Kit - What else is needed
0 Shovester Sighting
Last Post: DRAGSPORT
Last Post: MDT
0 WTB: Solo Seat for EFI XL
Last Post: rsscoggins
0 Xl/Buell drag bike parts
Last Post: Slojoe55
0 Have You Seen This? (New Harleys)
0 R.I.P.Aretha Franklin
Last Post: MDT
Last Post: lynnx
0 To crossover or not?
Last Post: jacsul
0 Gotta Start a Thread for the Streetfighter Too!
Last Post: jammantoo
Last Post: paulc
0 Where are the New Hampshire Sportsters?
0 C.O.B.B run west
Last Post: ReddTigger
0 Spark Plugs
Last Post: sltm1
0 Why cafe a sportster?
0 O2 Sensor, p/n 27719-07, is it 12mm or 18mm ? - 2011 XL1200CP
0 Is my clutch bad ? or is it in my head ?
0 Bonnie Truett of Drag Racing Fame
0 Vented or non-vented cap on 2009
0 It's xena's Birthday Today!
Last Post: fafcpa
0 How is 1969 xlch voltage dispersed and regulated.
Last Post: 72 Ironhead XLH
BobH (64), jcrow (64), release (63), Iron Joker (58), rickschad (55), mickes (54), indyrednek (54), jarhead08, koidac (42)
Old 4 Days Ago
JensWest JensWest is offline
JensWest is a splendid one to beholdJensWest is a splendid one to beholdJensWest is a splendid one to beholdJensWest is a splendid one to beholdJensWest is a splendid one to beholdJensWest is a splendid one to beholdJensWest is a splendid one to beholdJensWest is a splendid one to beholdJensWest is a splendid one to beholdJensWest is a splendid one to beholdJensWest is a splendid one to behold
Default Fuses instead of circuit breakers
Hi!
I'm planning on replacing the circuit breakers (1) in my -92 XLH 1200 for a small fuse box (something like 2).
Or would you suggest otherwise?
1.
2.
Thanks.
Old 4 Days Ago
Graywolf Graywolf is offline
The last several years of the hard mounts have blade type fuses.
Graywolf
Old 4 Days Ago
Yes. So, I also have an 1999 XL1200C, so figured it would work.
But it always feels better to have it confirmed, since my own knowledge regarding these things is relatively limited.
So there's nothing in perticular, other than A values, I need to think about?
I can go ahead and just switch 'em?
Old 4 Days Ago
Randy_rots is a glorious beacon of lightRandy_rots is a glorious beacon of lightRandy_rots is a glorious beacon of lightRandy_rots is a glorious beacon of lightRandy_rots is a glorious beacon of lightRandy_rots is a glorious beacon of lightRandy_rots is a glorious beacon of lightRandy_rots is a glorious beacon of lightRandy_rots is a glorious beacon of lightRandy_rots is a glorious beacon of lightRandy_rots is a glorious beacon of light
Just make sure you use blade type fuse box, because the one from your photo is unreliable non blade type fuse box.
Good luck
Old 4 Days Ago
Good luck
Thank you for your input.
And that was my plan. Just posted the wrong pic. in my post.
Thanks.
Old 4 Days Ago
Diogenes415's Avatar
Diogenes415 has a brilliant futureDiogenes415 has a brilliant futureDiogenes415 has a brilliant futureDiogenes415 has a brilliant futureDiogenes415 has a brilliant futureDiogenes415 has a brilliant futureDiogenes415 has a brilliant futureDiogenes415 has a brilliant futureDiogenes415 has a brilliant futureDiogenes415 has a brilliant futureDiogenes415 has a brilliant future
I'd opt for the mini blade type fuses since they are readily available and instead of going down to a 2 fuse block I'd probably go with a 4 fuse block (ignition, instruments, lights and accessories)... don't our 98-03 Sporties have 4 circuit breakers all of which are 15 amp?
BTW, I haven't seen many other people named Jens over the decades other than during the televised winter olympics or cyclist Jens Voigt.
Nope, it's a Sportster.
Old 4 Days Ago
Ah. The "2" in my first post was a pic. reference.
Yes, since there are 4 circuit breakers, my plan was to go with something like this (the one to the left):
It would be convenient with mini blade fuses, I agree, but I haven't been able find a box for such yet.
My -99 has 4 x 15 A blade fuses.
I see what you're saying.
I'm from Sweden and it's a bit more common name here.
Old 4 Days Ago
carry a tin of spares!
https://cdn.avweb.com/media/newspics...od0l10hja6.jpg
if i were to change setup, i would use this, reset-able, trip indication and theft deterrent.
