0 Xl/Buell drag bike parts
Last Post: Slojoe55
0 Have You Seen This? (New Harleys)
0 R.I.P.Aretha Franklin
Last Post: MDT
Last Post: lynnx
0 To crossover or not?
Last Post: jacsul
0 WTB: Solo Seat for EFI XL
Last Post: Jcolleyoh
0 Help removing speedo connector
0 Gotta Start a Thread for the Streetfighter Too!
Last Post: jammantoo
Last Post: paulc
0 Where are the New Hampshire Sportsters?
0 Big Bore Kit - What else is needed
0 C.O.B.B run west
Last Post: ReddTigger
0 Spark Plugs
Last Post: sltm1
0 Shovester Sighting
Last Post: Bwf347
0 Why cafe a sportster?
0 O2 Sensor, p/n 27719-07, is it 12mm or 18mm ? - 2011 XL1200CP
0 Is my clutch bad ? or is it in my head ?
0 Bonnie Truett of Drag Racing Fame
0 Vented or non-vented cap on 2009
Last Post: rsscoggins
0 It's xena's Birthday Today!
Last Post: fafcpa
0 How is 1969 xlch voltage dispersed and regulated.
Last Post: 72 Ironhead XLH
0 As far as maintenance goes...Cycle Electric or Alternator?
Last Post: JonesL
13 %~%#~wobble ^!^^#!#^
Last Post: Diogenes415
BobH (64), jcrow (64), release (63), Iron Joker (58), rickschad (55), mickes (54), indyrednek (54), jarhead08, koidac (42)
  #1081
cycowrencher's Avatar
The 30 tooth Evo Ind aluminium crank sprocket changes the primary ratio from 1.6:1 (35/56) to 1.86:1 (30/56). I also have a 57 tooth clutch basket to get 1.90:1... Close enough to 2.0...
madnss's Avatar
madnss madnss is offline
Sportster/Buell Model: 883 Xl
Two step parts in route! Kind of excited to hold the throttle wfo at launch!
Sweet. That kicks us out of the street class if we install one.
Anyone got a PBI 281-22 front...
brianbbs67's Avatar
I have been revived
Sportster/Buell Year: 1961
Sportster/Buell Year #2: 2010
Other Motorcycle Year: 1977
Here's my build for the winter. My dad's brother bike he won in 1953. This will take time.
I have to make this
IMG_1007 by brianbbs67, on Flickr
Into this
13503121_1764998320438514_1653854747907469511_o by brianbbs67, on Flickr
Ok, now I'm revived
Old 3 Days Ago
mac93 mac93 is offline
Sportster/Buell Model: 1200
Sportster/Buell Year: 95
Cool build, Looking forward to updates.
Old 1 Hour Ago
Here is the how to on cleaning up the shift drum and arms.
Here is the damage that the sharp edges cause in the arms.
Here is the untouched drum. Notice the hard edge on the channel.
Here is the arm after a quick clean up of the leading edge of the drum hole. You want to do this all the way around on both sides of all 3 arms.
Here is the angle you want to relieve the edge at.
Here is the angle you want to relieve all of the arm pathway on the drum at. You need to use a rotary file for hardened steel in a drill or die grinder for this.
Its a 40 minute job after you disassemble your trans... You will probably want to purchase and install the 2000+ shift detent as well since you already have it apart... Here is the old style for reference. The new style has deeper petals.
