Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE & BUELL MOTORCYCLE FORUM - GENERAL DISCUSSION > Organize a Group Buy
Organize a Group Buy Here is where you can organize a group buy. Anyone can organize a group buy to include commerical vendors. This is only section that non-supporting vendors may mention their products but only in conjunctions with a group buy.
Last Post: Yakcm2
0 Wheel fitment
Last Post: vagrant318
0 Coil OK but no Spark??
Last Post: Medyo Bastos
6 English newbie
Last Post: Limey Bloke
5 Tire Pressure?
Last Post: Joe_jeep
Last Post: motorfish
0 ultima electronic ignition
0 Fitting mini apes
Last Post: Joe_jeep
0 Power cones
0 S&S MGAL carb
Last Post: thefrenchowl
0 Forum member mug shots
0 .551 Cams in an EFI 1200
Last Post: Ghostdog
0 will these fit my 2006 xl 1200c
Last Post: mwXL 2006
0 Convert to wide glide front end
Last Post: 98SportyS
0 Noisy
0 93 Sporty Key replacement
0 can you tell me why?
0 Wheels
Last Post: NoRemorse
0 Wont shift from 1st to 2nd
Last Post: BoozeBeast
0 Pandemic just got wet!
Last Post: Joe_jeep
Last Post: Oldmxdog61u
Old 1st April 2013
gchristopher9 gchristopher9 is offline
Sportster/Buell Model: 1200c
gchristopher9 is just really nicegchristopher9 is just really nicegchristopher9 is just really nicegchristopher9 is just really nicegchristopher9 is just really nicegchristopher9 is just really nicegchristopher9 is just really nicegchristopher9 is just really nicegchristopher9 is just really nicegchristopher9 is just really nicegchristopher9 is just really nice
Default Group Buy - Vertical Plate mount that you've never seen before
Had a prototype made of a plate mount I designed, and everything worked out great. I have a couple small tweaks to make, but the overall size and plate location will be the same as what I have now. Going to beef up the bracket a little bit. I spoke to a local fabricator who says he can make them for $50 each if we can get a group together. Obviously would go down with more people involved. He can paint and clear coat in house for another $5, or powder coat outside for about $10 each. Figured I would start a group buy thread, as I'm not sure how many people have seen my other thread. Here are some photos of the prototype mount.
Anyone interested??
Old 1st April 2013
mick42's Avatar
mick42 mick42 is offline
Sportster/Buell Model: 1200Roadster
Other Motorcycle Model: BMW K1600GT
mick42 has a reputation beyond reputemick42 has a reputation beyond reputemick42 has a reputation beyond reputemick42 has a reputation beyond reputemick42 has a reputation beyond reputemick42 has a reputation beyond reputemick42 has a reputation beyond reputemick42 has a reputation beyond reputemick42 has a reputation beyond reputemick42 has a reputation beyond reputemick42 has a reputation beyond repute
You are not going to be able to get an inspection sticker with that in Mass.
Old 1st April 2013
I know the law requires horizontal plates. Not to worried about it. I had a cop behind me at a light the other day with this on. Also with expired inspection and registration stickers, and wasn't pulled over. I'll take my chances.
However, if people are interested in seeing it made as a horizontal mount, that could easily be done.
Old 1st April 2013
mick42's Avatar
the sticker is good untill May but you will not get another one.
Old 1st April 2013
rocketmangb's Avatar
Not legal in California.
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Old 1st April 2013
The sticker was good until May, LAST YEAR. Thanks for your concern though.
Old 1st April 2013
mr.coffee's Avatar
mr.coffee mr.coffee is offline
Sportster/Buell Model: XL883N
mr.coffee is a splendid one to beholdmr.coffee is a splendid one to beholdmr.coffee is a splendid one to beholdmr.coffee is a splendid one to beholdmr.coffee is a splendid one to beholdmr.coffee is a splendid one to beholdmr.coffee is a splendid one to beholdmr.coffee is a splendid one to beholdmr.coffee is a splendid one to beholdmr.coffee is a splendid one to beholdmr.coffee is a splendid one to behold
Weird...a thread about a plate bracket turns into a discussion about expired tags.
Let's talk about the bracket. There's lots of places where vertical plates are legal. It's actually a really clean look, I like it - very simple and uncluttered. How long have you been running it? Tell us more about the construction, what metal, what grade, what weight?
-m
Old 1st April 2013
Thank you Mr. Coffee.
It only has about 50 miles on it so far. It is made of 12 gauge steel and was mig welded at that seam. Since it is sprung weight, it should fare far better than the shock or axle mounted brackets. Not certain of the weight just yet, but part of the design tweaking is to add some holes the the large area that the plate attaches to, in order to decrease the weight. I'm also planning on making the small piece more of a triangular shape, instead of the "C" shape you can see in the first photo. This will make it much stronger than the one I had built already.
Old 1st April 2013
kkbii kkbii is offline
Sportster/Buell Model: XL1250s,tax paid
kkbii has a brilliant futurekkbii has a brilliant futurekkbii has a brilliant futurekkbii has a brilliant futurekkbii has a brilliant futurekkbii has a brilliant futurekkbii has a brilliant futurekkbii has a brilliant futurekkbii has a brilliant futurekkbii has a brilliant futurekkbii has a brilliant future
The plate has to be lighted in Wv. I do like the design and mounting location.
Old 1st April 2013
MA also requires lighting. Which can easily be added with a lighted plate frame or lighted bolts.
