Last Post: fafcpa
0 Craigslist
Last Post: Lone Rider
0 Michigan Thumb Run:
0 How to long term storage?
0 A couple more noob questions
Last Post: rjg883c
0 Wanted: Mid Controls for Frame Mount Evo
Last Post: 5mel42
0 A Day in the Life...
0 Laughing shotgun pipes...Kickstarter hits pipe
Last Post: Oldmxdog61u
0 points/condenser
0 Proper XLCH
Last Post: Joe_jeep
0 Momentary starter switch installation question
3 Start System Testing
Last Post: LetsDoIt
0 Short Shots w/mid controls
0 Ok 1200 to 1275 for street performance
0 Power cones
Last Post: Serious Blac
0 Lifter / Tappet Please Gimme a Hand
Last Post: nhfdias
0 Un-Modded 2013 Forty-Eight Wobble
0 Need help with ideas..
Last Post: robbie202
0 Problem on a trip
0 883 Highway Speed?
Last Post: SLW210
jlede (70), hissatsu (65), Mickey Shane (65), jiffylube (54), TEAMGREEN (49), pirogue1 (45), soupman77 (44), kromroykw (43), O48 (43), dracolich, STEVOMERCKX (35)
Old 30th March 2020
thecarnie thecarnie is offline
thecarnie is an unknown quantity at this point
Default My blow through turbo XL1200C
Been working on this thing for about 6 months. Still plenty of work to do, but its streetable now. I barely get on the forums and spend most of my time on facebook, but i just bought a new laptop to program the ignition and I figured I'd share here a little bit too. https://youtu.be/RXS2-naC7ek
Before the turbo project the bike was running Hammer Performance's 100hp package with the screaming eagle CNC heads. I had the heads redone by XLXB to open up the combustion chambers. They installed the shorter and larger twin cam valves, sinking them further into the head and deshrouded them. The process opened them up from 59cc to 72cc bringing the compression down to 9.2:1
IMG_0161 by Alexander Clawson, on Flickr
IMG_0158 by Alexander Clawson, on Flickr
IMG_0110 by Alexander Clawson, on Flickr
Old 31st March 2020
rocketmangb's Avatar
Welcome !
See ya at Sportster Junkies !
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Old 31st March 2020
NLXL's Avatar
NLXL NLXL is offline
Impressive!
Sportsterpedia
Old 3rd April 2020
GorilladaHun's Avatar
GorilladaHun GorilladaHun is offline
Sportster/Buell Model: 883 Superlow
Sportster/Buell Year: 2016
GorilladaHun is an unknown quantity at this point
Suzuki wheels and suspenders?
2016 883 Superlow
Old 3rd April 2020
The wheels brakes and forks came off a 96 Buell Lightning
Old 4th April 2020
Ah, yeah-shoulda thought about that massive rotor. The wheels are striking reminiscent of late 80's GSX-R units.
Old 4th April 2020
Jason's Sporty's Avatar
Jason's Sporty Jason's Sporty is offline
Sportster/Buell Model: Sportster XLH 883/1207
Sportster/Buell Year: 1986
Sportster/Buell Year #2: 1972
Jason's Sporty has a brilliant futureJason's Sporty has a brilliant futureJason's Sporty has a brilliant futureJason's Sporty has a brilliant futureJason's Sporty has a brilliant futureJason's Sporty has a brilliant futureJason's Sporty has a brilliant futureJason's Sporty has a brilliant futureJason's Sporty has a brilliant futureJason's Sporty has a brilliant futureJason's Sporty has a brilliant future
Video of this monster running please!!!!
Old 4th April 2020
Old 5th April 2020
hondo hondo is offline
Other Motorcycle Model: 2000 ZX12R/1998 T595
hondo has a spectacular aura abouthondo has a spectacular aura abouthondo has a spectacular aura abouthondo has a spectacular aura abouthondo has a spectacular aura abouthondo has a spectacular aura abouthondo has a spectacular aura abouthondo has a spectacular aura about
Very professionally done!
I'd like to see a video while your riding if one is available.
It looks like your cooling the pressurized air. What are you using as a cooling medium? Do you have an oil pump to evacuate the turbo? What Mikuni are you using? What did you have to do to pressurize the carburetor?
I'm messing around converting my Sportster to run on E85 now with a long term goal to add a blow through turbo. I've done a couple of mock-ups and I've decided the turbo will have to be mounted just about where yours is. My problem with a rubber mount is the turbo has to move with the engine so I've drawn up a plate that bolts to the crankcase where the stock exhaust bracket mounts so the turbo weight is not totally supported by the exhaust pipes.
Yellow Pearl 05 XL1200R:
Mikuni 42, .551, Doherty AC, Golan 5/16" FV, TC88a, Spark plugs indexed, Air caps on forks, Modified SE mufflers, Rear (red) turn signals are also running/brake lights, LED rear turn signal stalks, Front turn signals moved to lower tree, Laydown license plate, Fork brace, Sundowner seat, Whittlebeast hybrid rear shock mod, Arlen Ness Fairing.
Old 5th April 2020
I’m using 100% water, but at some point I’m going to add some water wetter or other corrosion protection. The oil return for the turbo is a 5/8” heater hose, no pump, just a few inches higher than the return. The carb is an HSR45, I had to change the needle/seat assembly to the smaller size to accommodate a pump fed system. That’s fed by a 1:1 FPR WITH 2.5psi of base pressure. I also had to hook up the vent to receive a boost reference to prevent the bowl from flooding. As far as the support on a rubber mount, you could easily use a flex pipe similar to what most cars use on the manifolds. Just have to completely support the turbo off the frame.
