0 How to long term storage?
0 A couple more noob questions
Last Post: rjg883c
0 Wanted: Mid Controls for Frame Mount Evo
Last Post: 5mel42
0 A Day in the Life...
0 Laughing shotgun pipes...Kickstarter hits pipe
Last Post: Oldmxdog61u
0 points/condenser
0 Proper XLCH
Last Post: Joe_jeep
0 Momentary starter switch installation question
0 Michigan Thumb Run:
Last Post: Joe_jeep
3 Start System Testing
Last Post: LetsDoIt
0 Short Shots w/mid controls
0 Ok 1200 to 1275 for street performance
0 Power cones
Last Post: Serious Blac
0 Lifter / Tappet Please Gimme a Hand
Last Post: nhfdias
0 Un-Modded 2013 Forty-Eight Wobble
0 Need help with ideas..
Last Post: robbie202
0 Problem on a trip
0 883 Highway Speed?
Last Post: SLW210
0 Turbo Progress
Last Post: Turbo Sporty 48
0 Getting Hammered
jlede (70), hissatsu (65), Mickey Shane (65), jiffylube (54), TEAMGREEN (49), pirogue1 (45), soupman77 (44), kromroykw (43), O48 (43), dracolich, STEVOMERCKX (35)
Old 27th March 2010
Cadillac's Avatar
Cadillac Cadillac is offline
Sportster/Buell Model: 883C
Sportster/Buell Model #2: Dyna Street Bob
Other Motorcycle Model: Kawasaki Vulcan 900C
Other Motorcycle Year: 2014
Cadillac is a jewel in the roughCadillac is a jewel in the roughCadillac is a jewel in the roughCadillac is a jewel in the roughCadillac is a jewel in the roughCadillac is a jewel in the roughCadillac is a jewel in the roughCadillac is a jewel in the roughCadillac is a jewel in the roughCadillac is a jewel in the roughCadillac is a jewel in the rough
Default Removing rear turn signals/rear fender
As I am new to all this, I was hoping I could do a quick writeup for other people like me needing a little help, so here goes (if this is in the wrong section please move it)
No, I dont have a service manual, which I should probably get one, I tend to learn by tearing into things. I am getting ready to put a side mount license plate/taillight, and new turn signals on, and chop my rear fender, so I took some pictures of the dissasembly to hopefully help all of you:
First thing is first however, get the bike on a lift, it will make your job 100x easier. All the bolts are under the fender so you really need access with the tire out of the way:
next, remove your shocks. this allows the rear wheel to drop down out of the way so you have easy access to the bolts:
Next you need to remove any bolts holding your (I think they are called, strut covers) on. (the chrome long piece that is attached to the turn signals). For me this meant I had to remove the pieces my luggage rack attaches too, as well as the bolt on the backside of each turn signal. DO NOT pull on the turn signals once the bolts are out. The torx bolt needed for the luggage rack holders on mine was a size 27 Torx bolt. Cant remember the size of the wrench I used on the other side, I believe I used a mix of 13mm, and 7/16, a couple other ones as well.
To remove the one closest to the turn signal, I had to take the amber lens off so I could get my ratchet back there. Next, using a phillips head screwdriver, remove the lens from your tail light. Im sorry I didnt take many pictures from here out because it was pretty straightforward. Behind the taillight you'll find a circuit board with 4 connectors in it. White is the left side rear turn signal, remove it, black is the right side rear turn signal, remove that, and the other two are the tail light and the overall signals from up front, remove both of those. There is a bolt holding that piece on, just take and remove that and the whole assembly pops off.
Now the more difficult part in removing the turn signals: The wires are clipped in, very easy to pop out of clips, but on the right side they are zip tied to the ECM signal, just cut the zip ties. The connectors to the turn signals wont easily fit through the whole (if at all) so to remove the turn signal, I just chopped the wires leaving enough room to splice my new turn signals into it.
Ths is the little whole youre trying to get everything through:
Finally, there is a bolt holding the fender to the frame, and 2 connectors for electrical (im assuming the ECM) at the front of the fender. Remove those and you end up with:
and
If you are planning on chopping your fender, as I am, I put blue painters tape on my fender (a 1"x1" piece) as marking while still on the bike so I knew I dont want to cut any higher than that place. Hope this helps.
I hope this helps people out who need it. Like I said, easiest way for me to learn is to just tear into it. Please, if you have input, add it and I will make edits to this to help keep it all together. I want this to be a decent writeup for people like me who havent done much of anything like this before. Thanks.
Old 27th March 2010
J.P.'s Avatar
J.P. J.P. is offline
Sportster/Buell Model: 883/1250 NRHS
Sportster/Buell Model #2: 883c (Wife's)
J.P. is a name known to allJ.P. is a name known to allJ.P. is a name known to allJ.P. is a name known to allJ.P. is a name known to allJ.P. is a name known to allJ.P. is a name known to allJ.P. is a name known to allJ.P. is a name known to allJ.P. is a name known to allJ.P. is a name known to all
good write up and great pics, however removing the shocks seems a little involved to me for just removing the fender. I took mine off while the bike was on the jiffy stand.
2008 XL 883/NRHS 1250, 94 HP and 81.5 torque: Stage 2 heads, Flat top ceramic coated pistons, 536 cams, 10.5:1 compression, Progressive 14.25" 412's, Progressive fork springs, Intiminators, Screaming Eagle Heavy Breather, Custom headers by Justin at Bishop's Custom Cycles with a Dan Moto carbon fiber can, Storz Performance Tail Section, Chainsikle rear sets, Superbrace Fork Brace, Daytona Steering Damper, Jagg oil cooler, Flanders Low Cafe Bars, RSD 1 1/2" risers, 8" Headlight, Bar end mirrors, Sport front fender
Old 27th March 2010
Cadillac's Avatar
Removing the shocks only takes a couple seconds and allows the wheel to drop out of the way which gives a ton more room to get your hands to the bolts underneath. It may not be necessary but I think in the long run it saves time. and you'll at least need to detach the tops to get the cover off.
Old 27th March 2010
donnieray's Avatar
donnieray donnieray is offline
Sportster/Buell Model: xlh 883/1250
donnieray is an unknown quantity at this point
It depends on the length of your shocks, mine are huggers so I had to remove them ass well.
Time tested. It just happened.
Old 28th March 2010
jpbaily1 jpbaily1 is offline
Sportster/Buell Model: 1200 L
jpbaily1 has disabled reputation
Kool, I am just taking my fender off & needed a refrence.
Great Job!
Old 28th March 2010
rocketmangb's Avatar
I went ahead and pulled the tire and wheel !
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Old 28th March 2010
And thanks to you I went from this to this since my last post
Old 28th March 2010
Just pulled the bolt from the top of the shock & used my jack. I would not condone this pratice for others. I am just a little nutz.
Old 31st March 2010
johnny_socko's Avatar
johnny_socko johnny_socko is offline
johnny_socko will become famous soon enoughjohnny_socko will become famous soon enoughjohnny_socko will become famous soon enoughjohnny_socko will become famous soon enoughjohnny_socko will become famous soon enoughjohnny_socko will become famous soon enough
Hey Cadillac- Great write-up and very informative! I'm doing this exact thing when I get the rear fender/tank rattlecanned. Also nice to see the pics for reference.
J
Old 8th April 2010
beano's Avatar
beano beano is offline
Sportster/Buell Model: 1200 xlr
beano is on a distinguished roadbeano is on a distinguished roadbeano is on a distinguished roadbeano is on a distinguished roadbeano is on a distinguished road
great write up ! thanks...b.
