0 BEST LONG CHROME fILTER FOR 2001 EVO sPORTSTER
Last Post: lewk
0 Clutch Stud Spacer: 1.530" pn #5995, 0.040" #5996, 0.080" #5997
0 6 month old battery discharged and now won't charge at all
Last Post: seajay
0 LaPera Left Side Solo Bag
Last Post: FiftySixer
0 DK Customs external Breather catch can location help
Last Post: Andy56
0 1981 XLH Getting Recranked
0 A different Oil filter test
Last Post: koolbreeze
Last Post: seajay
0 an old Lady
0 Fork Maintenance
Last Post: Mathias
0 Fuel delivery issues
0 Factory Chain Oiler
0 Align intake manifold
0 pop's through carb at,idle
0 oil light flickering
0 Slip on muffler
Last Post: LiveToRide57
0 Fork Gaiters
Last Post: tiderider
Last Post: Stray Cat
0 Gas Cap problem?
Last Post: ZTatZAU
0 23" wheel 4"over fork tubes
Last Post: class of 82
kuch73 kuch73 is offline
kuch73 is an unknown quantity at this point
Default EMGO drag slip on find...
I picked up a used 07 1200C that has some EMGO drag slip-ons with baffles installed, it sounds great, but it always had this strange squeaking sound coming from somewhere down low. Loud enough where my wife following behind me in the car could hear it and she says it sounds really loud. So, I get to checking things over with it running and could definitely hear it around the slip-ons. I pulled the heat shields back a tad from the pipes thinking that was it, nope, not it. Ended up pulling the baffles out of the pipes to see if they were flexing or rubbing in the pipes. both of the baffles had no baffling remaining but the wire was still in there moving against the pipes! I did an old school hot rodders trick and wrapped the baffles with steel wool and held it in place with the wire and reinstalled. Squeak is gone and it still sounds great. Thought I would pass this along.
2007 Sportster 1200 Custom, Pewter Metallic, EMGO drag slip-ons, 8 Mini Apes
