0 Torx screws on clutch cover
Last Post: 45Brit
0 gearing is too high ?
Last Post: Ronan978
0 Sadly Leaving
0 Need some advice on 1983 Ironhead
Last Post: flthd31
0 off idle stumble progress
Last Post: smm1200
Last Post: rocketnorton
0 Grenade Plate
Last Post: b0fh
0 Start up
Last Post: mickey t
Last Post: spacecoast
Last Post: mickey t
0 Another Sporty ADV Build
Last Post: shreksbro
0 First startup
Last Post: mickey t
0 DK Custom 3" Velocity Stack
Last Post: mesalkn
0 Power Loss At Sustained High RPMs
Last Post: smokey 2
0 Buell heads and cams!
Last Post: Clevspeed
0 Dirt bike front wheel??
0 Problem with my 1998 1200S
0 What oil and filter to use in 2005 1200c
0 Bike can't go over 75miles.
head bolt covers, parts wanted, primary gear
Old 16th July 2019
Pictures, your parts may be quite useable!
It's likely that something went through the chain to break it.
Or it was damaged by someone trying to pry it off without removing the motor sprocket.
Old 17th July 2019
doodah man's Avatar
Originally Posted by carlgrover View Post
...get a shifter and shift on the right.
You would also need a longer shift shaft as the stock ‘75/‘76 shaft terminates behind the cam cover.
