0 Torx screws on clutch cover
0 gearing is too high ?
Last Post: Ronan978
0 Sadly Leaving
0 Need some advice on 1983 Ironhead
Last Post: flthd31
0 off idle stumble progress
Last Post: smm1200
Last Post: rocketnorton
0 Grenade Plate
Last Post: b0fh
0 Start up
Last Post: mickey t
Last Post: spacecoast
Last Post: mickey t
0 Another Sporty ADV Build
Last Post: shreksbro
0 First startup
Last Post: mickey t
0 DK Custom 3" Velocity Stack
Last Post: mesalkn
0 Power Loss At Sustained High RPMs
Last Post: smokey 2
0 Buell heads and cams!
Last Post: Clevspeed
0 Dirt bike front wheel??
0 Problem with my 1998 1200S
0 What oil and filter to use in 2005 1200c
0 Bike can't go over 75miles.
Old 27th May 2019
OK - I changed the opening paragraph to reflect that... Thanks...
Old 16th July 2019
ParrotHead's Avatar
ParrotHead ParrotHead is online now
I am the great Cornholio!
Other Motorcycle Year: 1974
Originally Posted by Bluto View Post
Looks good, would only add that using the common fix of stock HD two steel plus one friction replacement for the spring plate also often squeals and has abrupt clutch takeup...that experience is what motivated me to go with the XR1200/Buell XB clutch parts, not problems with an an aftermarket clutch.
Bluto,
Since a few more months have passed I was wondering if you are still having good results with this fix.
John Wayne - "The Shootist"
Old 16th July 2019
Bluto Bluto is online now
Bluto,
Yep, still have zero squeal and clutch takeup is very smooth...
(Harley should have done this many years ago, they have to be aware of the "grenade plate" issues. FWIW I sent an email on this fix to their customer suggestion box months ago but never got a reply.)
Old 17th July 2019
ParrotHead's Avatar
Thanks for the update. Surdyke does not have some of the parts so I need to order from multiple sources.
I am sure they do, but in reality most bikes never have that failure because they don't get enough miles on them. Therefore no reason to fix the issue.
No reason for HD to fix it, huh
Strongly disagree with that, from what I've read here some spring plates fail in as little as 10,000 miles AND do some expensive damage. The parts guy at my local HD dealership is well aware of the issue and has some failed spring plates behind the counter. It would not cost HD more than a couple of bucks to build Sportsters at the factory with the XR1200 judder spring setup rather than the spring plate if there is even any price difference at all for the parts.
It would be right thing for HD to do and the cost would be insignificant...
jzink0883's Avatar
Sportster/Buell Year #2: 1998
BTW the spring has to go in the right way, the FSM section for the XR1200 clutch has a diagram that details this.
Bluto,
Great information. Thanks for sharing.
Question: Is there a short version of the “right way” to install the XR spring parts?
Look at the diagram at the Sportsterpedia Page:
http://sportsterpedia.com/doku.php/t...ef:priclutch02
jzink0883's Avatar
IXL2Relax,
Thanks for pointing me to Sportsterpedia. I should have known!
ParrotHead's Avatar
Just ordered the parts to do this fix on my 2006 Sporty. Once they come in and I install them I will post an update
