Last Post: bordens
Last Post: FiftySixer
0 Info needed on mini sumps.
Last Post: thefrenchowl
0 Ground Up Beginner Build
0 Chinese S&S carbs
0 "S" model specific Q&A
Last Post: Paul.W
0 Learning Wrenching Resources?
Last Post: Paul.W
0 Tappet blocks and tappets
0 XR mutt race bike progress
0 Sportster Fork Upgrade
Last Post: PetesPonies
0 WANTED, Mid Controls for 2002, 883 Sportster
Last Post: tylermiller
0 Why No Tachometer?
Last Post: Oldmxdog61u
0 Brotherhood of the traveling lid
Last Post: BigLerowski
Last Post: Edster
0 Coil readings
0 New guy from IL
Last Post: Bow only
0 Top end failure
Last Post: Tipofthelake
0 Valve Lengths?
0 3/4” Axle Drum Brake ??
0 primary cover
0 Why such heavy oil in Sportster?
0 Andrews 5th Gear Mainshaft Swap
Last Post: Diemos
daggar rider, The Brit (67), MGN54 (66), beau-kat, bkmthdff (55), af_sting (51), ofo (49), LOSTHIGHWAY420 (46), coxja (40), rickeybyrd (35)
  #2521
Old 5th June 2018
cycowrencher's Avatar
cycowrencher cycowrencher is offline
Other Motorcycle Model: 1984 KX 125
cycowrencher has much to be proud ofcycowrencher has much to be proud ofcycowrencher has much to be proud ofcycowrencher has much to be proud ofcycowrencher has much to be proud ofcycowrencher has much to be proud ofcycowrencher has much to be proud ofcycowrencher has much to be proud ofcycowrencher has much to be proud ofcycowrencher has much to be proud ofcycowrencher has much to be proud of
Originally Posted by Tinz View Post
Nice.... having a knowledgeable tuner is gold.
Yeah, especially when the guy is a very experienced pro stock bike tuner. He did in 90 seconds what would have taken me 2 weeks to figure out... I still cannot believe how much more power is available in the middle and up top now that the cylinders are not fighting each other. The timing indicators on the plug straps are in the middle if the bend now. Its also a tad lean now that the cylinder burn is completely using the fuel...
Sent from my LGLS992 using Tapatalk
USN 1991-1995 VFA-81/ USS Saratoga, Iraq 1, Kosovo/ Bosnia Conflict
Old 8th June 2018
madnss's Avatar
madnss madnss is offline
Sportster/Buell Model: 883 Xl
A few shots from track photographer last weekend
Old 8th June 2018
madnss's Avatar
Old 8th June 2018
Tinz Tinz is offline
Sportster/Buell Model: X1
Tinz has a reputation beyond reputeTinz has a reputation beyond reputeTinz has a reputation beyond reputeTinz has a reputation beyond reputeTinz has a reputation beyond reputeTinz has a reputation beyond reputeTinz has a reputation beyond reputeTinz has a reputation beyond reputeTinz has a reputation beyond reputeTinz has a reputation beyond reputeTinz has a reputation beyond repute
Great to be able to spend quality time with your son..
Old 8th June 2018
MatHormell's Avatar
MatHormell MatHormell is offline
Sportster/Buell Model: XL883R
Sportster/Buell Model #2: Buell XB12R
Other Motorcycle Model: Yamaha
MatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond repute
Been spending a lot of time on the mini express where is the hammer express hiding?
Sent from my SAMSUNG-SM-G890A using Tapatalk
HAMMER PERFORMANCE 90 Ci
CP .500 Dome Pistons
Axtel Cast Iron Cylinders
HAMMER PERFORMANCE .600 Cams
1.725 Ratio S&S Rocker Arms
HAMMER PERFORMANCE Intake Manifold
HSR 48 Miunki
XR1200 Crank Conversion W/ Case Mod 34T
HAMMER PERFORMANCE Sledge+ Head Work
2.020" Intake and 1.630" Exhaust Valves
Conical Valve Springs
S&S Premium Lifters
HAMMER PERFORMANCE Billet Push Rod Bases
Barnett Clutch Hub With Scorpion Clutch
Dynatek 2000i
R&D MOTORSPORTS- TRANSMISSION WORK-REM ISF
WorldWideBearings
Patriot Defender Exhaust
Old 8th June 2018
madnss's Avatar
Broke a clutch cable and I didn’t have it fixed in time. Fixed now and waiting for a 2” spacer for super D. It’ll be back out soon!
Old 8th June 2018
jcro61 jcro61 is offline
jcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud of
I knew that damn cable was the culprit!
this isn't just a trend homie, it's a lifestyle...
Old 9th June 2018
madnss's Avatar
You called it first! You’d think a stock cable 26 years old would last longer!!haha
Old 9th June 2018
Default Anyone go racing last weekend?
Where on the cable did it actually break?
Only 26 years? Wonder if it’s still under warranty?
Old 9th June 2018
madnss's Avatar
Yes, good stuff and thanks. We have the mx wheels back on and he’s going to race his first ever motorcross race tomorrow. Taking him and 2 of his riding buddies and we’re going to throw all 3 of them to the wolves and see how it goes! As long as they have fun, it’s a win!
