Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > REGIONAL FORUMS > Canada > Alberta
0 Info needed on mini sumps.
Last Post: thefrenchowl
0 Ground Up Beginner Build
0 Chinese S&S carbs
0 "S" model specific Q&A
Last Post: Paul.W
0 Learning Wrenching Resources?
Last Post: Paul.W
0 Tappet blocks and tappets
0 XR mutt race bike progress
0 Sportster Fork Upgrade
Last Post: PetesPonies
0 WANTED, Mid Controls for 2002, 883 Sportster
Last Post: tylermiller
0 Why No Tachometer?
Last Post: Oldmxdog61u
0 Brotherhood of the traveling lid
Last Post: BigLerowski
Last Post: Edster
0 Coil readings
0 New guy from IL
Last Post: Bow only
0 Top end failure
Last Post: Tipofthelake
0 Valve Lengths?
0 3/4” Axle Drum Brake ??
0 primary cover
0 Why such heavy oil in Sportster?
0 Andrews 5th Gear Mainshaft Swap
Last Post: Diemos
daggar rider, The Brit (67), MGN54 (66), beau-kat, bkmthdff (55), af_sting (51), ofo (49), LOSTHIGHWAY420 (46), coxja (40), rickeybyrd (35)
Old 18th April 2014
dwagar's Avatar
dwagar dwagar is offline
Sportster/Buell Model: 883L->1200L
dwagar is a splendid one to beholddwagar is a splendid one to beholddwagar is a splendid one to beholddwagar is a splendid one to beholddwagar is a splendid one to beholddwagar is a splendid one to beholddwagar is a splendid one to beholddwagar is a splendid one to beholddwagar is a splendid one to beholddwagar is a splendid one to beholddwagar is a splendid one to behold
Default Calgary - Two Wheel Sunday June 1
It'd be nice to see a good turnout for this.
Don - '06 883/1200L==>'14 FLD
Old 18th April 2014
Lenster's Avatar
Lenster Lenster is offline
Lenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond repute
Hey Don! I hope summer falls on that weekend this year!
We should hook up and go together.
Anyone else in the surrounding area want to hook up and arrive as a group?
Lenster's 1250 2006 XL1250C, Hammer Crush Heads, 15 Degree Pistons, 10.5:1 CR, S&S Roller Rockers, Fixed Length Pushrods, Jim's Powerglide II Hydraulic Lifters, RedShift 585 Cams, Energy 1 Clutch w/ 15% Stronger Spring, Hammer Performance Billet Intake Manifold, Mikuni HSR 45 (25 Pilot, 157.5 Main, 96 Needle 2nd Clip from top, Y6 Needle Jet), Offset Crush AC, Cobra Power Pro HP 2:1 Exhaust and a Daytona Twin Tec TC88A with a Kickass Map by Rico 05R.
Old 18th April 2014
dwagar's Avatar
That's a plan. I do have thermals I can wear if need be, lol.
Old 18th April 2014
AB,Frank's Avatar
AB,Frank AB,Frank is offline
serial Canuckian
Sportster/Buell Model: XL1250C
AB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond repute
Good thing its in Cow town,if it was in the chuck you'd have the leo's waiting with their decibel meters.
If I'm not working and its not snowing I just might head down! If its happening for me,I'll send Len an e-mail!
In three words I can sum up everything I've learned about life: it goes on.
Old 18th April 2014
NI-STR's Avatar
NI-STR NI-STR is offline
Sportster/Buell Model #2: Nightster
NI-STR is a splendid one to beholdNI-STR is a splendid one to beholdNI-STR is a splendid one to beholdNI-STR is a splendid one to beholdNI-STR is a splendid one to beholdNI-STR is a splendid one to beholdNI-STR is a splendid one to beholdNI-STR is a splendid one to beholdNI-STR is a splendid one to beholdNI-STR is a splendid one to beholdNI-STR is a splendid one to behold
Don't be so sure Frank. Calgary is doing "sound traps" too.
Ill keep this in mind.
Old 18th April 2014
dwagar's Avatar
Len posted an article in the Calgary Sound Laws thread. It appears they are giving up on it.
