Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > OFF TOPIC > Health and Fitness
Health and Fitness Here you can post and discuss health and fitness.
0 Looking for an xlch engine
Last Post: Medyo Bastos
0 Transmission issues
Last Post: bobber58
0 WTB: 1996 Sportster stock-ish exhaust and mid controls
Last Post: PRICHMON
0 Keihin Butterfly crack
Last Post: jasnoc
0 Cut Wiring, no spark.
0 Chinese S&S carbs
Last Post: 11B40
0 Info needed on mini sumps.
0 Top end failure
Last Post: Mission1
0 Ironhead high speed cruise prob
Last Post: Oldmxdog61u
0 First Harley - 1975 XL1000 Café Project
0 Belt Guards/Lowering Brackets
Last Post: Jcolleyoh
Last Post: SprtyXL
0 Rear Exhaust Tappet Mount Block
Last Post: knocknakilla
Last Post: james beam
Last Post: keithnh
0 Valve Lengths?
Last Post: motorhedmike
FORCE50 (68), marcus (55), gardkarlsen (50), dhoppe1 (42), Hagen (42), tdyer55 (38)
  #321
Old 11th April 2019
Tim The Grim's Avatar
Sportster/Buell Model #2: KHK
Sportster/Buell Year #2: 1954
Other Motorcycle Year: 96
I go back to work next Wednesday. My 1st heart attack didn’t hurt. I was running the control board on a bad day and felt chest pressure. It was diagnosed as an anxiety attack. My O2 saturation was only 88 but the EKG showed normal so they sent me back to work.
Two weeks before that I had climbed an 80 foot tall column twice in 6 minutes with no problems. I’m 65.
My 2nd didn’t hurt either. It was mid December, 4:20 am. I had been on nights for 2 months and this was my 12th 12.5 hr outside shift in a row. I just couldn’t make it up the hill to the control house for shift change. I made an excuse that I had to check on the stray cats I feed. 15 minutes later I was ok and made turnover at 5am. I just knew from that moment that something was wrong.
Dec 21, after 2 restful days off, I was cleaning litter boxes before going in on the 1st of 3 night shifts when I just couldn’t catch my breath. I took a shower and told my wife we should go to the new mini hospital down the road. My EKG was perfect but my Troponin level was slightly elevated. No pain just pressure and short of breath. The little hospital got the wheels turning.
3 hospitals, 2 EKGs, Cardiac Ultrasound, Cardiac Cath. A breathing test of some sort that broke the catheter seal on my Femoral Artery and finally a Quadruple Bypass on Christmas Eve. 5 days in the ICU and then home. My wife’s a nurse.
I was a walking time bomb but my heart suffered very little damage.
Since then I’ve been in some form of upper body pain every day. I got off the opiates at 25 days out. 6 days to detox. I had pneumonia 3 weeks ago and the blood thinners keep my nose on the edge of terrifying.
I’ve been in Cardiac Rehab for 20 sessions and it’s the most satisfying medical experience I’ve ever had.
Del Sol Cardiac Rehab ROCKS !!
Today I went back to the clinic at work and had my pre return to work checkup and did ok. Back to work 4/17. A week off each month and retire at Thanksgiving.
Old 11th April 2019
jcn59 jcn59 is offline
Sportster/Buell Model: 1200
Sportster/Buell Model #2: 1200
Sportster/Buell Year #2: 1994
Other Motorcycle Model: Aspencade
Other Motorcycle Year: 1986
jcn59 has a reputation beyond reputejcn59 has a reputation beyond reputejcn59 has a reputation beyond reputejcn59 has a reputation beyond reputejcn59 has a reputation beyond reputejcn59 has a reputation beyond reputejcn59 has a reputation beyond reputejcn59 has a reputation beyond reputejcn59 has a reputation beyond reputejcn59 has a reputation beyond reputejcn59 has a reputation beyond repute
I need to add something here. On 10/15/2015 at 2:00 a.m. on an elk hunting trip in the BigHorn mountains, a big wind blew in and devastated our tent camp. I injured my back picking up the mess. A few days later I went to the ER about my back. I explained in complete detail how I injured my back and the doctor, in his devine wisdom, ignored everything I said and determined that I must go in the hospital immediately because I was having a heart attack. He based his decision on a very slightly elevated troponin level. He didn't hear anything I said so I left the ER AMA. I went home and googled troponin and what I learned was that when the medical people first made the troponin connection, it's presence alone was sufficient to determine a heart attack. After a bit they learned that slightly elevated levels could be caused by PAIN. I went to my regular doctor of 15 years & he sent me to get an MRI. Guess what? The MRI showed a crushed disk around L-5 and a crack in the L-4 vertebrae. If the ER doctor would have opened his ears instead of his mouth, I may have gotten an accurate diagnosis.
My reason for writing this is that the doctors are not always right and if you disagree with your doctor, talk with him or see a different physician.
Gone but not forgotten: RD 350 Yam, Kaw 3 cyl. 500, Kaw 900 Z1, 750 Honda SS, etc.
Old 11th April 2019
TonyGall TonyGall is offline
TonyGall is an unknown quantity at this point
since my heart attack ive been getting very severe joint pain !! I had tests for arthritis and they come back with early onset arthritis, but the Dr said it shouldn't hurt so bad ?? my cardiac rehab nurse thinks it could be the high dose of statins making it worse ??? is anybody else who's on statins having the same problem ? it is a known side effect.
Old 11th April 2019
I had problems with a statin as it was increased years ago, and the doc switched me to a different one. Problems ended. My LDL was 115 when I had my HA; now about 65 on the LDL.
Old 12th April 2019
ChinCactus's Avatar
I was having pretty severe joint pain and a month off the statins didn't help. Diagnosed with rheumatoid arthritis. Now am on meds to control it and mostly pain free. Before that, when I was having a flair up it was extremely painful, so much so I couldn't walk!
Much better now.
Old 12th April 2019
Much better now.
im 5 weeks of the statins and its no better, going to see the rheumatoid guys in 2 weeks so hopefully they will sort it
Old 13th April 2019
Ireeman's Avatar
Ireeman Ireeman is offline
Asgardian
Sportster/Buell Model: 883r
Other Motorcycle Year: abov
Thank God de coupe playoffs have not started...
Go U mass!
Old 15th April 2019
Bama Lee XLC's Avatar
Bama Lee XLC Bama Lee XLC is offline
Bama Lee XLC has a reputation beyond reputeBama Lee XLC has a reputation beyond reputeBama Lee XLC has a reputation beyond reputeBama Lee XLC has a reputation beyond reputeBama Lee XLC has a reputation beyond reputeBama Lee XLC has a reputation beyond reputeBama Lee XLC has a reputation beyond reputeBama Lee XLC has a reputation beyond reputeBama Lee XLC has a reputation beyond reputeBama Lee XLC has a reputation beyond reputeBama Lee XLC has a reputation beyond repute
have them check for blood / oxygen starvation caused by partially blocked arteries elsewhere......should have been a BIG warning sign for ME
8/10/14 I had a massive heart attack
had been having joint pain for years because clogged arteries weren't letting enough oxygen enriched blood get to the joint tissues.
7 stents, 2 of which went into my ilieac arteries, and quitting the cigarettes later, i'm right as rain
the 2 stents in my ilieac arteries IMMEDIATELY relieved the joint pain that I thought were hips going bad,
'02 XL1200C Customed out by previous owner.
Old 15th April 2019
thanks for the info
Old 22nd April 2019
Nora44's Avatar
Nora44 Nora44 is offline
Sportster/Buell Model: BUELL Blast
Nora44 is an unknown quantity at this point
Get well soon. When i was in the cardiac unit, there was no phone, no TV, no visitors, nothing. They didn't want any outside stresses. I guess things have changed.
