Last Post: mrmom9r
0 73 XL 1000 Sportster - SOLENOID BYPASS
Last Post: 4th of July
0 Can’t go over 70mph
Last Post: SLW210
0 TC88A Maps for 883 to 1275 Basic Converstion
0 Reflectors...Yeah, or Neh
0 Chinese S&S carbs
Last Post: T. Clark
0 Recent 1275 Dyno Tune
0 Hammer 560 VS 570 Felt differences?
0 2006 XL1200 OEM Battery Dimensions
0 Swingarm has a slight twist
0 Cycle Cover for Sportster
Last Post: FiftySixer
0 Minnesota denied federal aid
0 Mikuni Knock Off "REVEALED" !!!
0 Tappet blocks and tappets
0 Headwork
0 Air filter Q
0 1982 front master cylinder sight glass replacement
0 New Member
merc, schvamf (48), MikeLightnin, o2man98 (40), Toadz (32), WingNut15B (32)
exhaust, mufflers, sportster
Old 18th September 2016
Synn187 Synn187 is offline
Sportster/Buell Model #2: Ironhead
Sportster/Buell Year #2: 1980
Synn187 is an unknown quantity at this point
Mine's an older sporty so just want to make sure they will fit. As I'm in Australia most everything has to be ordered from overseas
Old 19th September 2016
sportynewby7's Avatar
sportynewby7 sportynewby7 is offline
Sportster/Buell Model: XL883 w/ 1200 conversion
Sportster/Buell Year: 1990
Other Motorcycle Model: Suzuki Savage LS650 2004
sportynewby7 is an unknown quantity at this point
I think the fishtails are badass, and those come with baffles? those might be the ones for me, I wonder if they make some specific for sportsters.
bgavin bgavin is offline
Sportster/Buell Model: XL1200R, non-CA model
bgavin has much to be proud ofbgavin has much to be proud ofbgavin has much to be proud ofbgavin has much to be proud ofbgavin has much to be proud ofbgavin has much to be proud ofbgavin has much to be proud ofbgavin has much to be proud ofbgavin has much to be proud ofbgavin has much to be proud ofbgavin has much to be proud of
The Rush slipons are quite desirable.
If I did not already have a set of SE-II, I would have bought the Rush.
Hammer Performance tests a whole lot pipes.
Note the Rush gives up nothing to the top performing Patriot Defender from idle to 5600 rpm.
Above 5600 the Patriot pulls away.
Personally, if you want your bike to be "all that" above 5600 RPM, buy a rice rocket.
This is not meant to sound mean-spirited.
Sportsters are not rice rockets; they are for riders who want a Sportster.
Cycle Shack is in bankruptcy, and their slip-ons are hard to find.
IMO, the Rush are the right combination of sound and performance.
They are louder than the Screamin' Eagle (80503-07) that are 50-state street legal.
The new SE are top performers to 4,000. See the MotoUSA Shootout above.
The Crusher's Avatar
The Crusher The Crusher is offline
The Crusher has a reputation beyond reputeThe Crusher has a reputation beyond reputeThe Crusher has a reputation beyond reputeThe Crusher has a reputation beyond reputeThe Crusher has a reputation beyond reputeThe Crusher has a reputation beyond reputeThe Crusher has a reputation beyond reputeThe Crusher has a reputation beyond reputeThe Crusher has a reputation beyond reputeThe Crusher has a reputation beyond reputeThe Crusher has a reputation beyond repute
Although I have respect for the Hammer chart, it seems to escape comment that these tests are not run with the same motor, in the same build state, so they don't actually reflect the performance curves of a stock or mild build.
You can't keep a good man down......... unless you tie weights to his ankles.
xmikex xmikex is offline
Sportster/Buell Model: Iron
Sportster/Buell Year: 2014
xmikex has a spectacular aura aboutxmikex has a spectacular aura aboutxmikex has a spectacular aura aboutxmikex has a spectacular aura aboutxmikex has a spectacular aura aboutxmikex has a spectacular aura aboutxmikex has a spectacular aura aboutxmikex has a spectacular aura aboutxmikex has a spectacular aura about
It's all tested with the same bike... Read the intro at the top of the page and they state it's all tested on their "shop mule"
I went with rush because I don't / rarely run my bike past 5k so I get the performance of the patriot pipes but cheaper.
Actually, there are three bikes represented there and the shop mule undergoes various builds.
Look at the details of the bike build for the tests. It's posted right under the dyno chart.
I'm not saying it's not a reasonable reference but it's not as broad a reference as many people seem to think.
Old 20th September 2016
Ok I found a seller from the states (eBay) that has a set new that they say fit my bike. They only sell straight cut so that will have to do.
