0 Graduated to Ironhead
0 Inherited Ironhead
0 yost power tube guy
0 FDR Drive pothole did this...if u can believe it
0 Gearing Help
Last Post: evo1100
0 Looking for an xlch engine
Last Post: Medyo Bastos
0 Chinese S&S carbs
0 Top end failure
0 dieseling ? solenoid ? help
0 What a birthday I've had
0 41mm V-Twin Narrow-glide conversion for XL
Last Post: keithnh
0 Keihin Butterfly crack
0 Another Wrap Post
0 Info needed on mini sumps.
0 Cleaning carbon build-up
5 1988 xlh1200//// dynatech2000i shorting/grounding help
Last Post: jtb%sporty
0 Mikuni Fuel and Air Metering (possible modifications)
0 Ironhead carbs
0 harley SE SP Baffle modification
Last Post: cliffm
0 Fixing Digital Gear Indicator
Last Post: cliffm
GWR (68), Helimad (66), dragon62 (58), metromix (58), Repohio (57), acenorm (52), reblu (44), jesterdoc (44), glucky7 (42)
K2019 K2019 is offline
Sportster/Buell Year: 1969
K2019 is an unknown quantity at this point
Default 1970 - AntiG Batt and CE Gen vs Kick+Magneto
Hi XLForum
Longtime reading and looking on here, and just re-registered. I'd really appreciate some help, as a little lost on the technicals.
I'm building a 1970 to be a kind of XLR-esque lookalike.
I now need to decide whether to keep it kick only with magneto, or go new Antig batt and cycle electric gen?
Everything I read on the forums say, if it is set up for electric keep it - bike has the electric start. Is it that bad? The mag is fixed but I've got the manual retard kit from Morris. However, I do like my knees :-) so if it is that bad then I'm not that macho needing to keep kick only.
On the electric start --- i can't find a clear answer? Will and 8 cell work or do I need a 12 cell? Plus, do I need to buy the full ($$$) CE gen or just the part you bolt on to the end? Last question, is will a antig be small enough to hide away under a 'fake' p-pad on the rear fender (yes, i've got the original 14 3/4 shocks, plenty of room, can't hide in oil tank as running a GasBox tank - it's awesome?!).
I'll try and get some pics, as I really want to finish this build in the next month.
Thanks for any help!
K
smokey 2 smokey 2 is offline
Sportster/Buell Model: 1970 XLCH
Sportster/Buell Year: 1970
Other Motorcycle Model: Ultra Classic
smokey 2 is a glorious beacon of lightsmokey 2 is a glorious beacon of lightsmokey 2 is a glorious beacon of lightsmokey 2 is a glorious beacon of lightsmokey 2 is a glorious beacon of lightsmokey 2 is a glorious beacon of lightsmokey 2 is a glorious beacon of lightsmokey 2 is a glorious beacon of lightsmokey 2 is a glorious beacon of lightsmokey 2 is a glorious beacon of lightsmokey 2 is a glorious beacon of light
looking forward to some pics
WORK TO RIDE, RIDE TO WORK
JonesL JonesL is offline
Sportster/Buell Model: XL
Sportster/Buell Year: 1971
JonesL has a reputation beyond reputeJonesL has a reputation beyond reputeJonesL has a reputation beyond reputeJonesL has a reputation beyond reputeJonesL has a reputation beyond reputeJonesL has a reputation beyond reputeJonesL has a reputation beyond reputeJonesL has a reputation beyond reputeJonesL has a reputation beyond reputeJonesL has a reputation beyond reputeJonesL has a reputation beyond repute
I've got a '71 iron head and it has both kick and electric start. On the days you're feeling macho, kick is the way but it's also nice to be able to just reach down and push the button.
Make sure your battery and charging system are compatible. I was looking seriously at LIon until someone let me know that LIon batteries don't like generator charging systems. I ended up with a Yuasa AGM battery and have had good service out of it.
"If a camel flies, no one will laugh if it doesn't get very far".
Old 3 Days Ago
bobber58 bobber58 is offline
Senior Master Bike Builder
Sportster/Buell Model: XLH bobber
Sportster/Buell Year: 1964
Sportster/Buell Model #2: XLH
Other Motorcycle Model: 883 Iron
Other Motorcycle Year: 2010
bobber58 is a name known to allbobber58 is a name known to allbobber58 is a name known to allbobber58 is a name known to allbobber58 is a name known to allbobber58 is a name known to allbobber58 is a name known to allbobber58 is a name known to allbobber58 is a name known to allbobber58 is a name known to allbobber58 is a name known to all
Even if you run the mag, youre still going to want a Cycle Electric generator. You want the low output version since it's only powering the lights.
I run an AntiGravity batter on my electric start 74. You need the 12 cell. Get a complete Cycle Electric generator with built in regulator. I havent had a problem using it to charge my CE battery. It small, but I dont think its small enough to hide under a P pad. You might be able to make a box and mount it on top of the swing arm in front of the rear tire.
