0 Fixing Digital Gear Indicator
0 Ironhead carbs
0 Top end failure
Last Post: Mission1
0 Gearing Help
0 Info needed on mini sumps.
0 Graduated to Ironhead
0 Inherited Ironhead
0 yost power tube guy
0 FDR Drive pothole did this...if u can believe it
0 Looking for an xlch engine
Last Post: Medyo Bastos
0 Chinese S&S carbs
0 dieseling ? solenoid ? help
0 What a birthday I've had
0 41mm V-Twin Narrow-glide conversion for XL
Last Post: keithnh
0 Keihin Butterfly crack
0 Another Wrap Post
0 Cleaning carbon build-up
5 1988 xlh1200//// dynatech2000i shorting/grounding help
Last Post: jtb%sporty
0 Mikuni Fuel and Air Metering (possible modifications)
0 harley SE SP Baffle modification
Last Post: cliffm
Old 13 Hours Ago
Highly-Dangerous's Avatar
Highly-Dangerous Highly-Dangerous is online now
SPANIARD
Originally Posted by harley506d View Post
S'funny, i have never had to do that. Off imgbb i just copy the code i choose and paste in dialog box. Never used the "mountain " icon.
You are correct also... when you copy the BBcode it already carries the [IMG] codes on it.
The links the OP posted did not have the codes around them.
