0 Saturday Sportster Season 2
Last Post: bagster guy
Last Post: PoodlePunche
Last Post: wachuko
0 Need a rear fender
Last Post: 1skullster1
0 1999 S upgrades
0 It's been a great Ride!
0 Fried Engine?
0 Starting my project soon.
Last Post: ankered
0 Fiber Washer on Idler Gear
Last Post: DirtyHarry68
Last Post: Jtl2
Last Post: joe s
0 Bad Speedometer or Bad VSS?
Last Post: cookiemech
0 a man walks into a bar
0 My off-road build
Last Post: 84rzv500r
andrews, high compression, pb+, wiseco
Old 22nd April 2011
cycledelic cycledelic is offline
Sportster/Buell Model: 1973 XLCH
Sportster/Buell Year: .
Sportster/Buell Model #2: 1972 XLCH RACEBIKE
Other Motorcycle Model: 1958 PAN/SHOVEL CHOPPER
cycledelic is on a distinguished roadcycledelic is on a distinguished road
Default a bit more go.. but not to much. wiseco/pb+ set up
hi,
i picked up my 72 xlch in bits for a complete steal and im in the process of rebuilding it for street use. the heads had been ported and polished with new stock size valves,guides, spring etc.
the cylinders had been bored to .040 over. i have a friend who can get me cheap wisecos so i have a set of their forged 10:1 comp pistons coming for it.
i was thinking about putting a set of pb+ cams or just the exh. valve set they do.
im not looking to get to carried away on this bike as i have another im rebuilding for racing also
i have talked to a couple of guys with early 900cc sportsters that run high comp M.C pistons and they have pb's in the stock i think (59?) with everything else stock and they seem to run really good.
if anyone is running wisecos and pb's together or has done in the past and has any feedback, it would be great to hear.
or any other comments or recommendations would be appreciated
Old 22nd April 2011
78ironhead is a glorious beacon of light78ironhead is a glorious beacon of light78ironhead is a glorious beacon of light78ironhead is a glorious beacon of light78ironhead is a glorious beacon of light78ironhead is a glorious beacon of light78ironhead is a glorious beacon of light78ironhead is a glorious beacon of light78ironhead is a glorious beacon of light78ironhead is a glorious beacon of light78ironhead is a glorious beacon of light
This might help.
http://www.andrewsproducts.com/motor...sing_a_cam.htm
Old 22nd April 2011
alaska62sporty alaska62sporty is offline
Sportster/Buell Model: '74 XLCH engine
Sportster/Buell Year: 62
alaska62sporty has a spectacular aura aboutalaska62sporty has a spectacular aura aboutalaska62sporty has a spectacular aura aboutalaska62sporty has a spectacular aura aboutalaska62sporty has a spectacular aura aboutalaska62sporty has a spectacular aura aboutalaska62sporty has a spectacular aura aboutalaska62sporty has a spectacular aura aboutalaska62sporty has a spectacular aura aboutalaska62sporty has a spectacular aura aboutalaska62sporty has a spectacular aura about
Any competent machinist will need the pistons before they bore the cylinders. You might want to take the pistons and jugs to a machinist, or measure them yourself, to check the piston to bore clearance before assembly. I have no experience with PB+s, a lot of people on this forum seem to really like them, I think Andrews Y grind might be a better match, if you are running ported heads and higher compression.
Old 22nd April 2011
waza waza is offline
Sportster/Buell Year: 1979
Other Motorcycle Model: 1978 FLH Shovelhead
waza is just really nicewaza is just really nicewaza is just really nicewaza is just really nicewaza is just really nicewaza is just really nicewaza is just really nicewaza is just really nicewaza is just really nicewaza is just really nicewaza is just really nice
I am running the same set up, port heads,pb+& wiseco. Runs good, lites up about 3800 rpm
Old 22nd April 2011
hey, yeah i dont know what pistons they had bored them for but i measured them before ordering the new wisecos and will get them machined to suit once i have the pistons
