6th September 2012
Posts: 16 Sportster/Buell Model: 883XLH Sportster/Buell Year: 1990
Let's talk starters
I tried searching and found nothing on this subject. I recently did a 1200 conversion on my 1990 883. It's running 10.5:1 Wiseco pistons with the stock 883 heads. I believe I have a 1.0kW starter - with a Spyke solenoid starter button. The battery is a Braille B129 with 323 CCA. Before the conversion this thing would turn over with ease!! Since the rebuild, it really struggles. Now, I haven't done any diagnostics but have you guys run into this situation after a higher compression conversion?
I will be checking the battery's voltage this afternoon then charging it if it's low. I will also check the terminals, connections, and wires to ensure there's no issue there. I read about using dielectric grease or vaseline on the terminals/connections so I will do that as well.
Any help is GREATLY appreciated!
6th September 2012
Wait...What?
Posts: 2,518 Sportster/Buell Model: 88 inch modified Sportster/Buell Year: 2003 Sportster/Buell Model #2: iforgot Sportster/Buell Year #2: 80's Other Motorcycle Model: crs Other Motorcycle Year: 80's
6th September 2012
Posts: 2,946 Sportster/Buell Model: 1200C Sportster/Buell Year: 04
04/07 1275 BFH heads Darkhorse XB crank .600 cams S&S 1.725 rockers S&S precision lifters BDL+15% clutch TC88A HSR-45 S&S 3" ac LSR 2-1
6th September 2012
Posts: 1,715 Sportster/Buell Model: 883 Flat Track Racer Sportster/Buell Year: 2002 Sportster/Buell Model #2: RIP 1200S Sportster/Buell Year #2: 1999
My stock starter worked fine with 10.5:1
6th September 2012
A Million Facts & Figures
Posts: 10,456 Sportster/Buell Model: XL883 Sportster/Buell Year: 2007 Sportster/Buell Model #2: Buell Cyclone Sportster/Buell Year #2: 1999
Have you checked your cranking compression?
Where is the ignition timing?
Starter capability is not normally a problem on these bikes.
6th September 2012
I did briefly consider a Compu-Fire Gen III Starter just for weight savings. Maybe one day when I have money to literally burn. A light weight battery is much more bang for the buck.
6th September 2012
Posts: 2,611 Sportster/Buell Model: sportster Sportster/Buell Year: 2003 Sportster/Buell Model #2: 1200 xl sportster custom Sportster/Buell Year #2: 03 Other Motorcycle Model: 1200 low sportster Other Motorcycle Year: 06
holly crap you batterie dont put out much jam i just bought a new harly batterie for my 03 1200 it had 592cca how old is your batterie and whats your charging system like ?? maybe your getting a bad stater?
6th September 2012
I will check on this tonight. I figured I needed to give the rings time to seat before doing a compression test.
The battery was purchased in April. Like I said, it was working perfectly fine before the conversion. It has more than the required CCA (240 from what I've read) for a Sportster.
6th September 2012
To my knowlegde there is no such piston as a Wiseco 10.5:1 for use with 883 heads. Dished pistons are either 9.5:1 or 10:1 from Wiseco. Are you sure you have the correct pistons? They need to be a dished piston if being used with stock 883 heads. If they are flat tops they are way too high of compression.
6th September 2012
Looks like they're the 10.5:1 domed pistons. Looks like I might have to check the squish on this setup. Thanks for bringing this up!
