Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE FORUM > Buell Motorcycle Bottom End
0 Fried Engine?
0 Saturday Sportster Season 2
Last Post: bagster guy
Last Post: Captain Johnny
0 Starting my project soon.
Last Post: ankered
0 Fiber Washer on Idler Gear
Last Post: DirtyHarry68
Last Post: Jtl2
0 It's been a great Ride!
Last Post: ed_in_az
Last Post: joe s
0 Bad Speedometer or Bad VSS?
Last Post: cookiemech
0 Need a rear fender
Last Post: SporterII
0 1999 S upgrades
Last Post: 84rzv500r
0 a man walks into a bar
0 My off-road build
0 Allegheny 2023
Old 18th June 2019
gusm2's Avatar
gusm2 gusm2 is offline
Sportster/Buell Model: Cyclone M2
Other Motorcycle Model: Suzuki SV650
Other Motorcycle Year: 01
gusm2 has much to be proud ofgusm2 has much to be proud ofgusm2 has much to be proud ofgusm2 has much to be proud ofgusm2 has much to be proud ofgusm2 has much to be proud ofgusm2 has much to be proud ofgusm2 has much to be proud ofgusm2 has much to be proud ofgusm2 has much to be proud ofgusm2 has much to be proud of
Default Which cams ?
Maybe someone can help, I'm trying to decide which cams would be a replacement for my M2,it's a 99 thunderstorm engine, standard apart from wiseco pistons ,also there seems to be quite a difference in prices, I'm looking for a big more top end power
10.55@129.41
Old 18th June 2019
seajay's Avatar
seajay seajay is offline
Sportster/Buell Year: 04
Contact http://www.hammerperf.com/xlvalvetrain.shtml
04/07 1275 BFH heads Darkhorse XB crank .600 cams S&S 1.725 rockers S&S precision lifters BDL+15% clutch TC88A HSR-45 S&S 3" ac LSR 2-1
Old 18th June 2019
aswracing's Avatar
A Million Facts & Figures
Sportster/Buell Year #2: 1999
1999-2002 International M2's came with the SE .497 cams right from the factory (same as used in the X1 and S3). Part number 25648-91, 4th down in the table below:
These cams are well matched to the motor. The .497 lift is about the limit for the stock valvetrain hardware, the overlap/TDC lifts already pushes the piston-to-valve and valve-to-valve about as far as you should push it, and the 48 degree intake close timing is a good match for the stock 10:1 compression ratio.
Bottom line, the cams are well matched to the rest of the stock motor, and so long as the rest of the motor remains stock, there are no cam miracles that will make it run better. It's already an excellent set of cams for that motor.
Click Here to Contact Me
Old 19th June 2019
gusm2's Avatar
Thank you for your help
Old 25th June 2019
Cumofo Cumofo is offline
Sportster/Buell Model: XLH1200C
Cumofo is an unknown quantity at this point
Take my example of what not to do. I went and got the N6 from Andrews cuz I thought it would give me more power but I lost so much lower end and it was ridiculously not fun to ride the bike so I ended up going with the 536 has which are the same stock as the high output there you go! I also went to the weisco pop ups in a desperate attempt to restore some cranking pressure, which dropped into the 165-169 lbs range.
Old 28th July 2019
Sportster/Buell Model: XL1200. (Sold)
Sportster/Buell Model #2: Looking now
Other Motorcycle Model: FLHRI
256* @ .053” is a lot of cam. I didn’t know stock bikes had cams like that.
... but I build performance automotive engines and that would be on the edge of street-able.
Old 22nd December 2019
YMike322 YMike322 is offline
Sportster/Buell Model: Buell Lightning CityX XB9
YMike322 is an unknown quantity at this point
Thank you so much for sharing all this information. This is just something I was searching for my writing projects with https://buyessay.net/ as I am not an expert in this field, so I needed good material!
Old 15th September 2020
Samedward Samedward is offline
Sportster/Buell Model: None
Sportster/Buell Year: None
Samedward has much to be proud ofSamedward has much to be proud ofSamedward has much to be proud ofSamedward has much to be proud ofSamedward has much to be proud ofSamedward has much to be proud ofSamedward has much to be proud ofSamedward has much to be proud ofSamedward has much to be proud ofSamedward has much to be proud ofSamedward has much to be proud of
Bolt in (5 speed) 91'-'95 25648-91
The best option and feasible as well.
Bob F's Avatar
Bob F Bob F is offline
XLF LIFEMEMBER Im retired
That was great advice!!!
Old 19th September 2020
gusm2's Avatar
Update, I fitted Andrews N4s and initially was disappointed with the dyno figures as my rwhp was down from 94 to 89 but the torque was up from 83 to 89, I also shed almost 10lbs by fitting a lithium battery, got hold of a pair of standard 1200 jugs and had them rebored to suit my +30" pistons, I lost15lbs myself during the drags closed due to Covid season.
It's now doing 1.5 60 foot times and down to 10.93.
I'm quite pleased with it........... nitrous next ��
