0 What's up guys
0 No click
Last Post: HarleyAsh
0 1974 XLH Rebuild
Last Post: Gearhead88
Last Post: maltesefalcon
Last Post: jeffro57
0 Conversion Kit Choices
Last Post: bagster guy
Last Post: gearbanger
0 Change engine sprocket
Last Post: FrameMount1200
0 DK Custom Products License Plate Relocations
Last Post: Melnic
0 Pinehurst NC
Last Post: XL Ed
0 You can't tour on that!!!
0 FNG from Tuckasee
Last Post: PoodlePunche
0 Increase Low & Mid Range Torque w/ STOCK Exhaust! Get a Better Sound Too!
0 Primary Cover
0 cam options
0 Allegheny 2023
3 Wtb, Wts, Wtt, Wtg (Evos)
Last Post: wolfryder
0 Sumped oil.
baker 6 speed
Old 28th April 2022
Tomcatt Tomcatt is offline
Dazed & Confused
Other Motorcycle Year: 2015
Great info above.
I have a '17 1200 and have played with front belt sprockets from 28T to 31T. Keep in mind your rear tire circumference/diameter also plays a role.
28T front belt sprocket and a 160/60-17 rear tire (I don't remember what its' installed circumference/diameter is) gives me 20.5 mph/1,000 rpm in 5th gear so 60 mph is ~2,920 rpm and 80 mph is ~3,900 rpm. A 31T changes that to ~2,635 rpm @ 60 mph and ~3,515 rpm @ 80 mph.
IF I wanted gearing for runnin' down the road 75+ mph I'd run a 31T sprocket. It feels good at those cruise speeds but around town you're riding a bike with what is effectively a 4 speed. Not bad as 1st is usable for more than getting the bike rolling, but you spend more time feeling like the gear you're in is too low and the next is too high. I ran into this at last yrs Midwest M&G. I had a 30T installed and at the "group ride" speeds I was always between gears, 3rd & 4th. I wished I had a 28T installed.
Old 28th June 2022
Sirrom1's Avatar
Sirrom1 Sirrom1 is offline
XL Forum Bronze Supporting Vendor
Sportster/Buell Model: 883L
Other Motorcycle Model: Bonneville
Other Motorcycle Year: 1967
Sirrom1 has much to be proud ofSirrom1 has much to be proud ofSirrom1 has much to be proud ofSirrom1 has much to be proud ofSirrom1 has much to be proud ofSirrom1 has much to be proud ofSirrom1 has much to be proud ofSirrom1 has much to be proud ofSirrom1 has much to be proud ofSirrom1 has much to be proud ofSirrom1 has much to be proud of
Front pulleys are available 27 to 32 tooth; but which one is right for you?
Pick the one that gives you a cruise rpm (stock cams) of about 3k for a 1200, 3.2k for an 883. If you have different cams your rpm requirement may be higher.
Don't have a tach?
https://www.883sportster.com/rpm-mph-charts
The link is a chart with '91 up 883 & 1200's with rpm and mph with the different pulley sizes.
Decide what existing mph is comfortable for you. Match that mph on the chart and the rpm is in the next column.
Match that rpm with the mph you want to travel at, that is the pulley for you.
...I can't be outta gas,
I haven't turned around yet...
Old 28th June 2022
rejeanprimeau's Avatar
The worst thing I did to my Sportster was to install a 31 front sprocket. The loctite was not even dry the 28 went back on.
