0 Saturday Sportster Season 2
Last Post: PoodlePunche
Last Post: bagster guy
Last Post: wachuko
0 Need a rear fender
Last Post: 1skullster1
0 1999 S upgrades
0 It's been a great Ride!
0 Fried Engine?
0 Starting my project soon.
Last Post: ankered
0 Fiber Washer on Idler Gear
Last Post: DirtyHarry68
Last Post: Jtl2
Last Post: joe s
0 Bad Speedometer or Bad VSS?
Last Post: cookiemech
0 a man walks into a bar
0 My off-road build
Last Post: 84rzv500r
View Poll Results: which do you prefer?
Vance & Hines 142 47.65%
Screamin' Eagle Slash Cuts 57 19.13%
Get a 2-1 already... 88 29.53%
Who care's about HP, Get some LOUD Drags.. 19 6.38%
Multiple Choice Poll. Voters: 298. You may not vote on this poll
exhaust, v&h, vance and hines
Old 5th June 2008
ReddTigger's Avatar
Default Dyno Run, V&H straight shots vs. Screamin' Eagles
I posted this in the sticky, but I wanted to get some feedback as well as provide some information between the pipes.
Vance & Hines Straight Shots (Baffled with a lollipop)
Screamin' Eagle Slash Cut with Moddified Baffles (Holes cut out in baffles)
Screamin Eagle 1200 Heads 61cc 10° dome
.010 over 10° dome pistons
Screamin' Eagle 1200 Ignition.
Screamin' Eagle Air Box (original) with K&N filter
Stock Carb
Stock Cam
Stock Wires
States I've Ridden in
71.3 hp 70.8 tq
Old 5th June 2008
biknut's Avatar
biknut biknut is offline
Sportster/Buell Year: 1988
I not that impressed with the bottom end below 3300 rpm. With stock cams and that high of compression it seems like it should be at least 5 hp more? My experience with SE slip ons was about the same. I lost bottom end too.
Old 5th June 2008
wandrur's Avatar
wandrur wandrur is offline
Sportster/Buell Model: N/A
Sportster/Buell Year: N/A
Other Motorcycle Year: 2007
wandrur has a reputation beyond reputewandrur has a reputation beyond reputewandrur has a reputation beyond reputewandrur has a reputation beyond reputewandrur has a reputation beyond reputewandrur has a reputation beyond reputewandrur has a reputation beyond reputewandrur has a reputation beyond reputewandrur has a reputation beyond reputewandrur has a reputation beyond reputewandrur has a reputation beyond repute
I must say I like the torque of the V & H. But will a difference of 1-3 hp or ft/lbs really be that significant? I'd be making aesthetic decisions at this point, personally. Between those two, I like the look of the slash cuts over the straight shots. (You were wanted opinions like this, yes?)
Old 5th June 2008
biknut's Avatar
In a side by side roll on 3 hp looks huge.
From the choices allowed in this poll I vote for V&H because of looks, and the fact that they work pretty good. I don't like 2:1, I guess you all know that by now. Anyone that says HP doesn't matter is lying to themselves.
Old 5th June 2008
Hot Rod Sporty Hot Rod Sporty is offline
Hot Rod Sporty has much to be proud ofHot Rod Sporty has much to be proud ofHot Rod Sporty has much to be proud ofHot Rod Sporty has much to be proud ofHot Rod Sporty has much to be proud ofHot Rod Sporty has much to be proud ofHot Rod Sporty has much to be proud ofHot Rod Sporty has much to be proud ofHot Rod Sporty has much to be proud ofHot Rod Sporty has much to be proud ofHot Rod Sporty has much to be proud of
Looks like you're runnin' just a bit lean. I wonder what would happen to those numbers if you shim the needle up one notch. I bet they'd improve a horse or 3...and improve the torque number...
Old 5th June 2008
Lenster's Avatar
Lenster Lenster is offline
Lenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond repute
The AFR on the Graphs shows RICH, not Lean.
Old 5th June 2008
You're right. My bad....
Old 5th June 2008
ReddTigger's Avatar
the bike was set a little rich, so that when I got down to sea level, it'll be right on the money.
Old 5th June 2008
ReddTigger's Avatar
I'm not worried about a 3 hp at the MAX of the scale. when I'll roll it on, it'll be just about the same. with a little more torque..
Torque gets you going,
HP keeps you going.
Old 6th June 2008
biknut's Avatar
HP keeps you going.
A lot of roll on's start at about 50-60 mph. I'm just saying it looks a little weak down there for stock cams and high compression. Maybe about 5 HP.
