0 Saturday Sportster Season 2
Last Post: bagster guy
Last Post: PoodlePunche
Last Post: wachuko
0 Need a rear fender
Last Post: 1skullster1
0 1999 S upgrades
0 It's been a great Ride!
0 Fried Engine?
0 Starting my project soon.
Last Post: ankered
0 Fiber Washer on Idler Gear
Last Post: DirtyHarry68
Last Post: Jtl2
Last Post: joe s
0 Bad Speedometer or Bad VSS?
Last Post: cookiemech
0 a man walks into a bar
0 My off-road build
Last Post: 84rzv500r
1200, 883, heads, high compression, spark knock
Old 31st January 2009
Don Burton's Avatar
More like 20% more efficient.. Using straight gas I can easily get over 50mpg. while using e-10, I barely break 40mpg..
I can't comment on your bike or setup but E-10 has between 3 and 4 % percent less energy than gasoline. I have also heard some others say that there was a very noticeable difference in mileage on their machines. That said, I can say that on my bike, I really don't notice much mileage difference between the two although I'm sure there is a small measurable difference if I actually cared to measure it accurately.
xlint89 xlint89 is offline
Sportster/Buell Year: 89
xlint89 has a spectacular aura aboutxlint89 has a spectacular aura aboutxlint89 has a spectacular aura aboutxlint89 has a spectacular aura aboutxlint89 has a spectacular aura aboutxlint89 has a spectacular aura aboutxlint89 has a spectacular aura aboutxlint89 has a spectacular aura aboutxlint89 has a spectacular aura aboutxlint89 has a spectacular aura aboutxlint89 has a spectacular aura about
Is it running? Take it for a ride.
V6 cams has 264 duration with 490 lift. Would make sense to run for higher compression with 883 heads.
Even dished pistons can have up to 10.5:1
I'm no expert, but would think it should run pretty good.
rottenralph's Avatar
I had 883 heads that were ported by yours truly, n8 cams, flattop pistons, smoothed chambers, thunderheader, and super E. I made 74 h.p. and 78 torque with 105 ambinent temp in the dyno room. The bike would wheelie on throttle and was fun to ridethat way. I liked the combo.
XLinAL's Avatar
XLinAL XLinAL is offline
Riding with Angels
Sportster/Buell Model: Chrome Yellow XL883>1200C
XLinAL will become famous soon enoughXLinAL will become famous soon enoughXLinAL will become famous soon enoughXLinAL will become famous soon enoughXLinAL will become famous soon enoughXLinAL will become famous soon enoughXLinAL will become famous soon enough
Originally Posted by Copper_King View Post
I bought a 1990 sportster motor that i thought was stock until we went through it.. it turns out that it has andrews V6 cams, high compression pistons, and 883 heads... I am curious how others think this motor will run. I've talked to people who say it should be hella mean, but im curious to know how it will do running on the street.. I know i will need to run higher octane (been told E-85 will work wonders, like it does in turbo cars, high comp. motors etc. to take care of spark knock) but I just wanted a few more opinions. Hopefully I got myself a runner.. Anybody else have a motor similar? 1200 with 883 heads? let me know what your ideas are or what you know?!?! Thanks in advance to everyone who can help me out!!!
I have an "01 883>1200.
It's got Wiseco 10.0:1 dishtop pistons, .536 cams, worked-over 883 heads and it will slide you off the seat and lift the front end if you whack the throttle coming out of a turn.
Haven't had it dynoed in this configuration yet, but it was making 74 hp and 79 ft-lbs before the cams and w/ different pipes.
I run premium gas and try to find non-e10 stuff when I can to keep the pinging away.
Richard
2001 XL883>1200C
"Dream as if you'll live forever, live as if you'll die today"
- James Dean
Old 4th February 2009
Copper_King Copper_King is offline
Sportster/Buell Model: 1200 rigid/springer
Sportster/Buell Year: 1990
Sportster/Buell Model #2: 1971 CB750 Chopper
Sportster/Buell Year #2: 2002
Other Motorcycle Model: Suzuki GSX-R1000 drag
Copper_King is an unknown quantity at this point
Thanks to all that replied. I have been extremely busy and not had much time to get on and reply to anyone. To answer a few questions, the heads ARE STOCK, I'm doing research on the E85, but I have been told it should work.. suggested was to mix with gasoline, slowly increasing the amount of E85 until i found the right ratio or found out it was fine with running on E85 alone.. this will be researched more.. It sounds like this motor will be a lil finicky, but lots of fun.. I'm not planning on riding it across the country, just taking it out and ridin' the shit out of it on nice days when I've got the time.. so economically friendly is no big deal here.. I guess getting it to run at its best will just be a matter of trials until I find out what works best.. A learning experience thtat will stick with me for and be nice to know for future refference in future motors i purchase/build.. Just another day in the modified life.
