0 Range With EFI 4.5 Gal Tank
Last Post: jzink0883
0 1275 Kit and Krome Werks Headers?
Last Post: carbonizedeyesockets
0 Member "Wedge" Heads for 1275 Conversion
0 Speedometer Replacement - 2011 xl1200cp - how to remove
0 wavers
0 900cc Cylinders
Last Post: FiftySixer
0 Hagerty Insurance
Last Post: Akdawg
Last Post: Slytat
0 CV-40 for 88’ 883 Still leaks overflow/rebuilt
Last Post: Mission1
0 tachometer on 2012 Custom
Last Post: The Doctor71
0 Kinda of a Dumb Question on Top End Build coming up
Last Post: XL1275
0 Early Sportster Shock Absorber Disassembly
Last Post: Heff
0 New from Michigan
Last Post: 1skullster1
0 Fuel Sputter & Much More
0 Another Ohio Meet & Eat?
0 Rear wheel alignment
0 low rpm problem
Desertfox (70), gd714 (60), insalltm (57), seagullplayer (55), ac_tx, jon686 (49), NineSixteen (45), dstroy12 (38)
  #51
Old 13th August 2019
When you say "spring washer" is this the same as a "lock washer"?
Lock Washer
Yes.In terms of providing any real "locking" they're next to useless. If you want a nut to stay put use a Nylok or Loctite.
Originally Posted by harley506d View Post
If he bought an axle for what he thought was for a '99 hub then the head length is too long so the axle is not going in far enough. The head will contact the first spacer too early leaving the usable shaft too short. Look at the axle specs in Sportsterpedia.
Look at his pics. The head length works out just fine without an un-necessary spacer on the right side. Shoulder against the inner bearing race is a perfectly acceptable arrangement.
I was always taught that you replace these everytime you take them off, but you know how that goes. They worked OK before the Nylok came along.
Lotsa vibration testing results out there if you want to look. Spring type lock washers have never been more than marginally better just a plain washer.
