0 N65C or N65A
0 Roadster CX Cafe Build
Last Post: b0fh
0 new to me 883
0 C.O.B.B. CBD oil
Last Post: davidbarker8
0 ,09 Iron883N idling weird, sputters on accelerating from idle or low revs.
0 First time poster, second time Sportster - XL1200C in California
14 Mid controls??
Last Post: Nicktree1200
Last Post: spamer80
0 Caterpillar Oil Filter
0 Getting ready to try firing it up after a year long rebuid
0 Tool to remove giant screws
0 Mid West Meet & Greet
Last Post: Traxx
0 Frame bracket
Last Post: Magneto Sportster
0 Ve tables for iron 883 with 1250 conversion
Last Post: Bikeaholic
0 dealer key pricing
0 Arun Floods
0 my recent ebay purchase
0 Cough and sputter resolved
Last Post: Whitewalls
0 Anyone know where I can get one of these mini fairings?
Last Post: 09Nightsterrider
3 Wtb, Wts, Wtt, Wtg (Evos)
Last Post: slamtry
0 my only real beef with my 03 883
Last Post: burely
cbsportster (69), sjeccles (52), 2011_Nightster (52), reeb (49), Maff (49), jl_rotary (42), UMLsilva (34)
  #31
Old 13th December 2019
Scott Scott is offline
Sportster/Buell Year: 1981
Other Motorcycle Year: 2002
Originally Posted by Fatylonghous View Post
Where’d you find your iron head rearsets?
Wow - old post given new life. That bike has changed so much since those photos that it's now barely recognizable.
Pegs are based on the stock passenger peg mounting bracket on my '81 - the one that bolts to the rear motor mount with 3/8"-24 bolts. I don't know if earlier years had a bracket like this; subsequent years did. I cut the clevis-style passenger peg mounts off the ends and welded on 1/4" thick steel plate to mount the pegs to. I cut the round portion off the 1/4" (or so) factory mounting plate and rotated it forward to raise the pegs higher up.
I attached a generic set of pegs and controls through a hole in that plate that replaces the stock factory passenger footpeg mounts. I got them somewhere for free; I don't know who makes them. Pegs and controls like them can be found many places, like eBay - universal rearsets that mount to any type of frame section or mounting bracket. The shift side linkage was a bit tricky. Each end uses a 1/4" heim joint - one left and the other right hand threaded for easy adjustability. I spent a good deal of time experimenting with spacing on both ends to clear the primary cover.
The right linkage simply pushes the female plunger of the rear master cylinder, which I had to relocate.
Old 14th December 2019
This is an old photo (prior to XR parts finding their way onto it) and I'm putting this here because when this whole thing started, I wasn't able to find too many photos of IH rearsets while looking for ideas. I thought this thread needed one more photo - this one is to show the mount for the rear master cylinder. That's 1/8" aluminum and mounts using the 1/4"-20 holes for the sprocket cover. Some spacing was required to clear the sprocket and get the master cylinder in line with the brake lever. I can't remember which version this is; I made and remade that piece of aluminum many times to get the angle of the master cylinder right.
Sorry for the size. Imgur won't let me size the image correctly, and this site won't let me delete the post.
rejeanprimeau's Avatar
I see the size perfect.
Strange things happen.
Old 15th December 2019
size looks fine to me.if you want to edit one your posts uses the edit function.
