0 16" Front mag wheel
0 Modify my dyna 2ki ignition
Last Post: painterdude923
0 Bigger rear Pulley
Last Post: SLW210
Last Post: TUCCI
0 '86 1100 basket build
0 Changed gas cap and experienced problems
Last Post: TUCCI
0 fork reflectors
0 Magneto base for 70 XLCH
Last Post: Monte03
0 Bike not started for 5 years
Last Post: robbie202
0 Is static timing enough?
0 high milage sportsters
Last Post: Bored now
0 flat earther bites dust trying to prove the earth is flat
0 Stacking the Alto Carbonite clutch !
Last Post: spitfirechopper
0 2021 Harley-Davidson Bronx
3 Wtb, Wts, Wtt, Wtg (Evos)
Last Post: Onlybckroads
0 su carb question
Last Post: trappnman
0 How much can I get for my sporty?
Last Post: IronheadPhil
Last Post: Kbetts
0 Quick brake question...
Last Post: tussuck
0 Plug for Siren
Last Post: brixtonanima
0 Where we are! Put yourself on the Map.
0 LIQUIMOLY oil additive whose using it?
Last Post: TUCCI
2 My 1275 Hammer Conversion..
nailhead (78), Rooster (63), chidovampiro (61), daniel (58), evereyken (57), RogueXR9OO (57)
Old 23rd November 2019
This gallon of varnish at Grainger has a halfway reasonable price but I see nothing about drying time or hardness.
https://www.grainger.com/product/SPR...-Varnish-6KDY3
It seems the TDS for the gallon has either has vanished or is not available.
No thinner specs or baking specs.
The gallon would still need to be thinned for good viscosity run.
Spray can (material specs should be the same although dry / curing time would be different).
https://www.paintdocs.com/docs/webPD...0601000&lang=2
Sprayon EL601 Red Insulating Varnish
PERFORMANCE
• SPECiFiCATiON: MEETS PERFORMANCE REquiREMENTS
OF ASTM d 115-07 4.2 PERFORMANCE FOR:
4.2.1 Drainage: 22%
4.2.2 Time of Drying: See drying schedule
4.2.3 Build: 2.9 mm
4.2.8 Oil Resistance: See chemical resitance
TEMPERATURE CLASS: Class F (155°C / 310°F)
• dRy hEAT RESiSTANCE:
Constant: 310°F
Intermittently: 400°F
• DIELECTRIC STRENGTH:
(ASTM D 115-07) Clear: 2,300 VPM
• ONE WEEK HARDNESS:
(ASTM D 3363 SHORE A 24hr / 1 Week): 6B
• FLEXIBILITY: (ASTM D 522) Pass
• CHEMICAL RESISTANCE:
Aliphatic hydrocarbon solvents: Moderate
Alkalis: Modarate
Aromatic hydrocarbon solvents: Severe
Chlorinated solvents: Severe
Salt water: Severe
Glycol ethers, alcohols: Severe
Inorganic acids: Severe
Organic acids: Severe
Oils: Severe
DRYING TIME @ 70°F @ 50% R.H.:
To Touch: 10 Minuntes
To handle: 15-30 Minutes (Tack Free)
Full cure: 7 Days
