0 16" Front mag wheel
0 Modify my dyna 2ki ignition
Last Post: painterdude923
0 Bigger rear Pulley
Last Post: SLW210
Last Post: TUCCI
0 '86 1100 basket build
Last Post: TUCCI
0 fork reflectors
0 Magneto base for 70 XLCH
Last Post: Monte03
Last Post: robbie202
0 Is static timing enough?
0 high milage sportsters
Last Post: Bored now
0 Stacking the Alto Carbonite clutch !
Last Post: spitfirechopper
0 2021 Harley-Davidson Bronx
3 Wtb, Wts, Wtt, Wtg (Evos)
Last Post: Onlybckroads
0 su carb question
Last Post: trappnman
0 How much can I get for my sporty?
Last Post: IronheadPhil
Last Post: Kbetts
0 Quick brake question...
Last Post: tussuck
0 Plug for Siren
Last Post: brixtonanima
0 Where we are! Put yourself on the Map.
Last Post: TUCCI
2 My 1275 Hammer Conversion..
nailhead (78), Rooster (63), chidovampiro (61), daniel (58), evereyken (57), RogueXR9OO (57)
  #6501
Old 28th November 2019
ktp1598's Avatar
ktp1598 ktp1598 is offline
Sportster/Buell Model: XL883N
Sportster/Buell Year: 2015
ktp1598 is a name known to allktp1598 is a name known to allktp1598 is a name known to allktp1598 is a name known to allktp1598 is a name known to allktp1598 is a name known to allktp1598 is a name known to allktp1598 is a name known to allktp1598 is a name known to allktp1598 is a name known to allktp1598 is a name known to all
Unfortunately it's not a '15. It's a 2011. I run premium anyway so hopefully no knock.
2011 XL1200C
Old 29th November 2019
Ghostdog's Avatar
Ghostdog Ghostdog is offline
Sportster/Buell Model: Sportster iron 883>1275
Sportster/Buell Year: 2016
Ghostdog is a name known to allGhostdog is a name known to allGhostdog is a name known to allGhostdog is a name known to allGhostdog is a name known to allGhostdog is a name known to allGhostdog is a name known to allGhostdog is a name known to allGhostdog is a name known to allGhostdog is a name known to allGhostdog is a name known to all
Originally Posted by Tomcatt View Post
Make sure you have minimum spec squish clearance when you do your build. Cometic sells .010" base gaskets and the "std" .020" gasket.
1275 kit is already on there , got about 3000 miles on it , I’ll be swapping heads and cams this winter if I can afford to send them out to Hammer to get done . I want to take out the n4’s that are in there and put in the 551 e cams , squish is good and gaskets as well , thank you for the heads up .
Ghostdog 2016 iron883<1275 Hammer prefomance kit, energy one extra plate clutch, 15percent spring,N4 cams, ported 883 heads ,danmoto 2-1 exaughst ,Dynojet powervision tuner .
Old 30th November 2019
60Gunner's Avatar
60Gunner 60Gunner is offline
Chief of Security
What are you tring to accomplish? Better low end? You DO know there's only a 2° difference in the intake close between the N4s and 551s. 46° vs 44°. You're doing headwork to change cams? And going with 551s?
Seems like a lot of money and trouble to gain nothing.
Seems to me I saw a thread where Aaron explained all this to you quite some time ago.
Unless I'm missing something you're flushing money down the proverbial shitter.
Not to mention the very real possibility your motor will sound like its ready to blow up with the 551s like so many have reported.
60Gunner's Avatar
Chief of Security
Here's the thread
Ghostdog's Avatar
I’m just trying to acomplish getting rid of the n4 cams because of how close the clearence is , Arron said that even though I don’t hear anything is hitting , it dosent mean it’s not happening so I know the 551 e cams have a much better tdc number and will have no clearance issues . My N4 cams are very noisy already so I highly doubt the 551 cam will be much worse. The head work is a separate thing that i would like to have done because I want bigger valves and comp valve job and porting , my heads now have been ported but still have the stock valve sizes . So why not go with better heads when I can afford it . Am I missing something? I thought bigger valves is a good thing no? Just don’t want to buy new pistons for a few more until the top end needs to be freshend up . So for rite now that was going to be this winters / springs plan
Old 2nd December 2019
83XLX's Avatar
83XLX 83XLX is offline
Sportster/Buell Model: XLX-61
Other Motorcycle Year: 1969
Finally had a decent day to ride and filled it up with non-ethanol on the way home.
Folkie's Avatar
Folkie Folkie is online now
Brass Nut
this could do with a dedicated thread of its own.
I've moved the relevant posts to a new thread here.
Folkie
South East England Riders
npaisnel npaisnel is offline
Sportster/Buell Model: XL883 now 1200
Sportster/Buell Year #2: 1993
npaisnel has a brilliant futurenpaisnel has a brilliant futurenpaisnel has a brilliant futurenpaisnel has a brilliant futurenpaisnel has a brilliant futurenpaisnel has a brilliant futurenpaisnel has a brilliant futurenpaisnel has a brilliant futurenpaisnel has a brilliant futurenpaisnel has a brilliant futurenpaisnel has a brilliant future
Brought it home with dyno chart after Hammer 1275 kit and N4 cams
91ft lbs torque
84 HP
At 5500 rpm
83XLX,
Beautiful bike. I like the simple, stock look. About 90% of my changes and upgrades are internal, so I always have that "warm and fuzzy" feeling from knowing why it's running so well.
I'm glad you had a chance to ride again. I keep a 5-gallon can of non-ethanol in the garage to refill my tank after my rides. In the off-season, I add stabilizer to it. The oil has already been changed, so it's clean inside and out.
60Gunner's Avatar
Chief of Security
91ft lbs torque
84 HP
At 5500 rpm
Well...post the dyno!
Currently Active Users Viewing This Thread: 7 (1 members and 6 guests)
Blowupster
