Keep & Kill
Snippets
25th September 2019
Posts: 67 Sportster/Buell Model: 883 Sportster/Buell Year: 2001
Buell upper end on 883 Sporty
I have a nice low mileage 2001 883....I can get my hands on a good running Buell Lightning engine, it's the type with the plastic overs over the pushrods but it's a fuel injection engine.....Can the heads and cylinders from the Buell bolt onto my 883? Is they any easy way to adapt a carb onto the ijection heads? Thanks
650 Triumph LSR modified production pushrod 133.1 mph....
25th September 2019
I looked around some and it appears a later model FI manifold can be modified for a carb....So if the heads and cylinders bolt on, that would be nice...
25th September 2019
Posts: 14,932 Sportster/Buell Model: XL1460C Sportster/Buell Year: 2000 Sportster/Buell Model #2: XL1200R Sportster/Buell Year #2: 2006 Other Motorcycle Model: XL1200R Other Motorcycle Year: 2004
I believe Hammer Performance offers a manifold as well, good people.
26th September 2019
Thanks, do you know if the cylinders and heads will fit?
26th September 2019
Posts: 22,189 Sportster/Buell Model: XL1200C Sportster/Buell Year: 2006 Sportster/Buell Model #2: XL1200C Sportster/Buell Year #2: 2006 Other Motorcycle Model: 48 "Totalled" By a Douche Other Motorcycle Year: 2012
What years is the Buell ?
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
26th September 2019
I think so, but if you visit the “Hammer Performance” stir they have many good technical sections, one in particular addresses heads and usage.
27th September 2019
Originally Posted by rocketmangb
what years is the buell ?
2004....
27th September 2019
Seems that was downdraft FI and the bolt pattern is the same as carb heads.
27th September 2019
27th September 2019
Thanks...So it all should fit with the usual precautions and proper assembly...I can sent my 883 heads to Hammer and for about $2000 have fine running 1200...Or piece together for maybe half the money and have a bit less in the long run...I do have time and like build engines....So....
