0 What Is the Advantage - Shovster?
0 WTB 04-06 intake manifold
0 Steering Neck Tapered Bearin Kit
Last Post: SportsterXLCH1967
0 1970 XLH smoke from rocker box gasket
Last Post: Rolschnee
0 1970 XLH Tach cable kinked
0 Canadians for sturgis 2021
Last Post: Knuckles
0 Fuse Box Pictures Wanted
Last Post: Blacky
0 Exhaust paint, coatings for head pipes?
0 2009 883 Wheel Issue
Last Post: Blacky
0 Iron 1966 XLRTT
Last Post: Model H
0 New here - compression test produced meh results.
0 S&S Super B help
0 Non-Starter, Compression Test Results
Last Post: Gravitas
0 Swing arm bearing change
0 2018 Iron 1275 Project
Last Post: yelladox
0 Homemade Lithium Battery
Last Post: t120r
0 What to do now? Ironhead clutch hub nut stripped
Last Post: Firefight
0 1968 ex barn dweller thread
Last Post: fernf5
0 Swingarm Fitment
Last Post: Blacky
0 yost power tube guy
0 S&S Super E
Last Post: CMCSSeabee
Last Post: Magneto Sportster
0 I made a oopsie
Last Post: robbie202
WinXP (70), Maggie (64), grancan1 (56), SRKASM (50), metalmessiah, o113attitude (46), stinkynate (38), wingman_214 (37)
case repair, trans reinforcement
  #181
Chuckthebeatertruck's Avatar
Chuckthebeatertruck Chuckthebeatertruck is online now
Sportster/Buell Model: Xlh
Sportster/Buell Year: 1959
Sportster/Buell Year #2: 1969
Other Motorcycle Year: 1969
And, here are some more photos so those of you who are a bit "handy" can make your own.
I'm not seeing the photos I posted; so here's another try at it:
Steve9's Avatar
Steve9 Steve9 is online now
Sportster/Buell Model #2: XL
Other Motorcycle Model: FXDC
That's a nicely thought out solution!
Steve
'01 Cyclone
'13 FXDC 96" stock
Tim The Grim's Avatar
MetalWorkingXLFan
Sportster/Buell Model #2: KHK
Sportster/Buell Year #2: 1954
Other Motorcycle Year: 97
Simply Fantastic. Kudos to all involved.
DirtyHarry68's Avatar
DirtyHarry68 DirtyHarry68 is offline
Sportster/Buell Model: 1968
DirtyHarry68 has disabled reputation
Nice, Chuck. Gets around the variations in the boss diameter too, I guess? The Doc made a big deal of that and I went to a lot of trouble to size mine.
Old 1 Day Ago
Sportster/Buell Year: 1969
When I did mine I pressed it in place and welded it. Then I used a dremel tool to match the existing oil groove. After removing speedo drive gear and grinding off lip I pressed in new bearing, inserted countershaft and gears into case to verify free smooth operation.
