Last Post: Rolschnee
0 1970 XLH Tach cable kinked
0 Canadians for sturgis 2021
Last Post: Knuckles
0 Fuse Box Pictures Wanted
Last Post: Blacky
0 2009 883 Wheel Issue
Last Post: Blacky
0 Iron 1966 XLRTT
Last Post: Model H
0 S&S Super B help
Last Post: Gravitas
0 Swing arm bearing change
Last Post: SportsterXLCH1967
0 2018 Iron 1275 Project
Last Post: yelladox
0 Homemade Lithium Battery
Last Post: t120r
Last Post: Firefight
0 1968 ex barn dweller thread
Last Post: fernf5
Last Post: mikethebike61
0 WTB 04-06 intake manifold
0 Swingarm Fitment
Last Post: Blacky
0 yost power tube guy
Last Post: cazz1000
0 S&S Super E
Last Post: CMCSSeabee
Last Post: Magneto Sportster
0 I made a oopsie
Last Post: robbie202
0 RIP Trainman
  #171
well i'll be different.in the shimmed at.075 pic. the rocker arm appears to be centered over the stem at half lift.offset equally in both directions at zero lift and full lift.call it a comprimise.
billeuze's Avatar
billeuze billeuze is offline
Sportster/Buell Year: 80s
Other Motorcycle Year: 1983
billeuze has a reputation beyond reputebilleuze has a reputation beyond reputebilleuze has a reputation beyond reputebilleuze has a reputation beyond reputebilleuze has a reputation beyond reputebilleuze has a reputation beyond reputebilleuze has a reputation beyond reputebilleuze has a reputation beyond reputebilleuze has a reputation beyond reputebilleuze has a reputation beyond reputebilleuze has a reputation beyond repute
Well from what I’ve learned, centred over valve stem is less important than rocker arm angle. In the article linked by Maxeffort, they say to scribe a line on the rocker arm marking line from rocker arm pad to center axis of shaft, and use that to test for correct geometry (perpendicular to valve stem at 1/2 lift). I did a crude version of this it told me that my last photo (+.155) is actually the best geometry of the three. But visually, the second photos look better to me. I will revisit the other method to test. I will scribe a more accurate line and confirm my findings. I may be going to a thicker shim after all.
''visually'' that's what i was using.visuallizing that that correct angle would be centered on the valve stem at 1/2 lift.
Maxeffort's Avatar
Momentary Specialist
Sportster/Buell Model: XL1200
The only caveat is the Shovelhead rocker system may not have been designed to be 90* to the valve at mid lift. (Modern rocker systems are, but not always the old stuff).
I would be still be looking at that, but also considering what part of the rocker pad is contacting the valve and the contact pattern on the valve tip.
I will agree (now that I’m viewing on a bigger screen) that #2 with .075” shim looks good as far as the rocker pad on the valve tip.
“Smooth roads, Blue skies and Green lights”
Sportster/Buell Year: 1969
Since pushing the valve stem sideways tends to wear guides out you're smart for thinking things out thoroughly. I would be looking into cutting up and modifying the rocker boxes to position the rocker shaft where it needs to be for the correct geometry. I'm not 100% certain on this but I believe the S&S Shovelhead engines utilize a twin cam style shovelhead rocker box. That maybe your ticket right there.
Maxeffort's Avatar
It’s easy to get carried away with this stuff. It’s good to check and research.
But taking a moment and remembering that this is an all Shovelhead top end
and the OP has decided to correct the pushrod cup angle by cutting and welding.
I think all that’s needed on the valve side is to optimize the rocker box height. It’s not going to be radically different than stock. There is increased valve height from the head work/valve job. There is the stack up of parts, but that’s about it. It seems reasonable that a modest shim job will put it into good shape.
kitabel kitabel is offline
Sportster/Buell Year: 1989
So far, much of the comments have been w/r/t getting the rocker's contact pad in a good position as to lift, scrub pattern etc.
When this is done, the short (pushrod side) exhaust rocker levers are both going to be pointing to directly above where the shovelhead cam would be, which is many inches away from where the actual XL exhaust cams are.
The intake levers are doing the same thing (not aiming at the cam lobe), but the error is much smaller.
billeuze's Avatar
correct, MOST of the comments have been regarding the valve end of the rockers because that is what I'm focusing on now. The pushrod end has been discussed a few timed here as well as my intention to focus on it AFTER I settle on what to do with the valve end. Because the is the logical order to do it.
billeuze's Avatar
Im not cutting up the rocker boxes - that would be going way outside the scope of this project. I'm also not going to consider using S&S rocker boxes. I don't have unlimited funds and am trying to work with what I have. besides my current rocker boxes have already had the pushrod cover sockets welded and machined by Ron Trock Sr. to point at the ironhead cams. New rocker boxes would still require that to be done and I don't have the tooling for it and since I am in Canada, it would probably cost me more to ship them back and forth to Ron Trock Jr. than he would charge for the work.
Yes
billeuze's Avatar
Changing the box position can be done in any increment you like... but adding material is annoying (thin shims). You only get .766 to .788 X the height change at the stem due to the valve's 40 degree angle (shovels are 40 and 38?).
Yes, It seems strange and I wondered if I had miss-measured. So I googled and found that its true. I learned that more precisely the intake angle is 40.25 degrees and the exhaust is 38.25.
