0 1970 XLH Tach cable kinked
Last Post: Rolschnee
0 Canadians for sturgis 2021
Last Post: Knuckles
0 Fuse Box Pictures Wanted
Last Post: Blacky
0 2009 883 Wheel Issue
Last Post: Blacky
0 Iron 1966 XLRTT
Last Post: Model H
0 S&S Super B help
Last Post: Gravitas
0 Swing arm bearing change
Last Post: SportsterXLCH1967
0 2018 Iron 1275 Project
Last Post: yelladox
0 Homemade Lithium Battery
Last Post: t120r
Last Post: Firefight
0 1968 ex barn dweller thread
Last Post: fernf5
Last Post: mikethebike61
0 WTB 04-06 intake manifold
0 Swingarm Fitment
Last Post: Blacky
0 yost power tube guy
Last Post: cazz1000
0 S&S Super E
Last Post: CMCSSeabee
Last Post: Magneto Sportster
0 I made a oopsie
Last Post: robbie202
0 RIP Trainman
Old 13th July 2020
Maxeffort's Avatar
Momentary Specialist
Sportster/Buell Model: XL1200
So, doesn't this crank lower the compression again?
I read it as going to a longer stroke
The longer the stroke, the more compression (assuming chamber size, bore, piston dome, etc.. stay the same)
“Smooth roads, Blue skies and Green lights”
Old 13th July 2020
billeuze's Avatar
billeuze billeuze is offline
Sportster/Buell Year: 80s
Other Motorcycle Year: 1983
billeuze has a reputation beyond reputebilleuze has a reputation beyond reputebilleuze has a reputation beyond reputebilleuze has a reputation beyond reputebilleuze has a reputation beyond reputebilleuze has a reputation beyond reputebilleuze has a reputation beyond reputebilleuze has a reputation beyond reputebilleuze has a reputation beyond reputebilleuze has a reputation beyond reputebilleuze has a reputation beyond repute
Yes, I’ll have to deal with that by milling the heads and/or the cylinders
Old 13th July 2020
billeuze's Avatar
The bigger t&o wheels I purchased would have increased the stroke and compression. But I broke them do I am back to my s&s 4-1/2” wheels.
Old 13th July 2020
davixlrtt's Avatar
davixlrtt davixlrtt is offline
Sportster/Buell Model: 1965 xlch
Sportster/Buell Model #2: 1991 Honda XR600
Other Motorcycle Model: 1986 suzuki gsxr 750.
davixlrtt has a brilliant futuredavixlrtt has a brilliant futuredavixlrtt has a brilliant futuredavixlrtt has a brilliant futuredavixlrtt has a brilliant futuredavixlrtt has a brilliant futuredavixlrtt has a brilliant futuredavixlrtt has a brilliant futuredavixlrtt has a brilliant futuredavixlrtt has a brilliant futuredavixlrtt has a brilliant future
Bill, I know that the crank assembly fell from the bench, but what part about it has actually been damaged enough to render the wheels useless?
........Davi.
Old 13th July 2020
billeuze's Avatar
Originally Posted by kitabel View Post
Where is your quench clearance?
I don't have my notes with me. But that will be dealt with and accounted for at the same time as milling the heads to increase compression ratio
I've no contact with one of these engines, the throttle response must be great with the small OD (7-7/16" vs. 8-1/2") and light weight (20 lbs? vs. 25 for S&S BT).
I hope so, we'll see...
Old 13th July 2020
wedge's Avatar
wedge wedge is offline
Davi asked my next question. I'm not even involved and this is driving me nuts. I have been in your place once and it just drains the blood from your brain. In my case the wife and I were installing a very expensive redwood sign that was already attached to the posts. We leaned it against a tree for me to take a quick survey of the holes to be sure we were ready and I heard that same sickening sound as it hit the ground after a gust of wind knocked it over. Split the face into a few pieces, so we loaded it back into the truck and went straight into making another one.
In your case, I think we all want for you to find a solution that has you using the new wheels.
Old 13th July 2020
billeuze's Avatar
........Davi.
Good question. Maybe they do still have a use.
I cannot get the crankpin anywhere close to true on them anymore. I can force it to true but then as soon as I apply more torque it goes way out of true again. I don't remember how much they are out but it is definitely closer to .01" than .001"
So what has been damaged? I think the tapers. I assume that with the momentum of the assembly landing on the floor, something had to give, or break, or bounce. So with the hard steel crankpin in relatively softer cast iron flywheel tapers, it is the cast iron that gave, deformed. I also assume that if we tried to correct the taper by re-machining that would make the taper bigger so the crank would go in deeper pinching the connecting rods.
If anyone knows otherwise or would have a use for these "damaged" flywheels, let me know.
Old 13th July 2020
Diameter of stock sportster flywheels = 7-7/8"
Old 13th July 2020
good looking video bill.when i was taught to check flywheels it was to hold the rods across your fingers in an open hand and turn the flywheel assy with your opposite hand.doe's anyone else do it that way?
Old 13th July 2020
Ferrous Head's Avatar
Blind Owl
Sportster/Buell Year #2: 1966
Paperweights ?
If it helps any, with the 4.5 inch wheels you don't actually have to move the oil holes.
And in theory the shorter stroke will allow higher revs which the Shovel Heads will be able to feed.
You should probably always skim alloy heads in any case so not really any extra cost there.
With the alloy heads you can up the compression more than you can with the cast iron Sportster version.
How much to take off ?
Dunno about that with Shovel heads. I would do a dry assembly and do a measure. Your also going to need to cc the combustion chamber to get a ball park figure.
It's not going to be "Super" critical either way. Too little of and you wind up with less compression than is optimal which you can correct by skimming again.
Too much can be alleviated by running thicker head gaskets.
The real go would be to try for some quench area. Then accept whatever clearance is required for that.
